Old May 26, 2010, 08:55 AM
martin_metal_88's Avatar
Default Hole in a Rad
Hey guys, most of you know that i am building my first WC setup and now I have a major issue. This morning I was FINALLY assembling thing when the door ring. I get surprised by the sound so I drop my screw driver in the rad. I hate you UPS guys bringing me some Fk*** OCZ ram. Now there is a hole in the rad and it is leaking. The hole is at the opposite side of the in\out hole so on the top at the complete back of the rad. If you guys have advice how to fix it please tell me so i can carry on building my loop. Or it will take 2 or 3 additionnal week to buy another rad. Maybe more. Thx you HWC!
Old May 26, 2010, 09:12 AM
Jackquelegs's Avatar
I use JB Waterweld. Grab it from Canadian tire. Essentially you gotta use epoxy
Iapetos
Zephyranthes
Old May 26, 2010, 09:25 AM
I'll take a look at this probably tomorrow! my work is like 500M off a canadian tire.
Any other advice are welcome!!!
Old May 26, 2010, 09:27 AM
Grab any kind of epoxy in any home hardware store
Iapetos
Zephyranthes
Old May 26, 2010, 09:34 AM
ok. Maybe I have some here. But well I will still wait for tomorrow becasue this annoyed me to a point! I wont touch hardware anymore for today!
Old May 26, 2010, 09:43 AM
LionRed's Avatar
Put a raw egg in it to stop the leak.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old May 26, 2010, 09:55 AM
Raw egg??? what the hell is that Some expression that you find common are wierd to me, that's the weak point of being french canadian
Old May 26, 2010, 10:09 AM
LionRed's Avatar
Hehe that's how they use to stop leaks in older car rads.
Old May 26, 2010, 10:36 AM
gingerbee's Avatar
use jb weld use the long set stuff not the quick have used it to fix many many rads very easy to use. do not use an egg it's an old car trick to keep you running, like the pantyhose thing. or if you have a soldiering iron you can just do it that way both work well jb weld is crazy strong so i go with that.
Old May 26, 2010, 10:39 AM
howpet's Avatar
If a rad shop or welding shop is nearby have braze in the hole with copper filler.
closing off side fan hole? edisleado Air Cooling 4 January 21, 2010 04:36 PM
Fan Hole & Radiator Template Downloads Mnpctech Guides & How-to's 6 October 30, 2009 03:07 AM
Hole in antistatic bag SuperFriedFish Troubleshooting 11 August 5, 2008 06:06 PM
Hole Saw Question miggs78 Cases 11 July 14, 2008 04:37 PM
hole mounts on a 1900XT same as HD3870 maxxxxel Water Cooling 0 June 27, 2008 07:14 AM
