  #31 (permalink)
Old May 26, 2010, 08:55 PM
Originally Posted by MpG View Post
That's my point - quick-set epoxy usually has those warnings, the longer-setting stuff doesn't. So best to use the latter.
Ah sorry, I misunderstood what you meant.
  #32 (permalink)
Old May 27, 2010, 03:31 AM
gingerbee's Avatar
jb weld is liquid steel it's going to out last the rad use period. adn even i no how to solder but where it is solder is going to make more of a mess ( he's never solder a rad before hence why i said jb weld. very easy 100% strong ) trust your own judgement your smart guy. jbweld is much stronger then solder do some test yoursefl.
closing off side fan hole? edisleado Air Cooling 4 January 21, 2010 04:36 PM
Fan Hole & Radiator Template Downloads Mnpctech Guides & How-to's 6 October 30, 2009 03:07 AM
Hole in antistatic bag SuperFriedFish Troubleshooting 11 August 5, 2008 06:06 PM
Hole Saw Question miggs78 Cases 11 July 14, 2008 04:37 PM
hole mounts on a 1900XT same as HD3870 maxxxxel Water Cooling 0 June 27, 2008 07:14 AM
