Old May 26, 2010, 10:52 AM
martin_metal_88's Avatar
Thx you all guys for advice I think I will try epoxy soon probably tomorrow if I can find some.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old May 26, 2010, 10:59 AM
gingerbee's Avatar
Originally Posted by howpet View Post
If a rad shop or welding shop is nearby have braze in the hole with copper filler.
this is the best option
Old May 26, 2010, 12:16 PM
I just want to know, the hole I have to fix is about the size of the head of a 11/64'' mesh. Will it work great with epoxy on a such big hole or?
Ask for more
Martin_metal_88
Old May 26, 2010, 01:43 PM
gingerbee's Avatar
yes i fixed a nickel sized hole this way in the summer time. very carefully that's was the biggest hole i have every fixed for a computer rad ( well it was being used fro a computer rad he he ) and i ended up throwing the rad out ha ha. bad flow
Old May 26, 2010, 01:58 PM
Well the only thing I want is to make it work without leak at least for the summer to give me some time to buy another one that will fit my ATCS ( I have to mod the rad to fit it in ).
Ask for more
Martin_metal_88
Old May 26, 2010, 02:37 PM
MpG's Avatar
MpG MpG is offline
If you use epoxy, make sure it's not the 5-minute set stuff, which isn't technically rated for constant exposure to water. Use the stuff that takes a long time to dry.
Old May 26, 2010, 02:46 PM
My father told me he have 6-8 hours one in the tool chest so I will probably use this one since 8 hours is long and probably enough for long water exposure.
Ask for more
Martin_metal_88
Old May 26, 2010, 03:19 PM
MpG's Avatar
MpG MpG is offline
Just double-check the packaging. The warning is usually "Not for submersion" or "Not for sustained exposure to water", or something like that, if it's an issue.
  #19 (permalink)
Old May 26, 2010, 03:44 PM
I'll promise you I will look at it and ask my father to be sure it's the right thing;)
Ask for more
Martin_metal_88
  #20 (permalink)
Old May 26, 2010, 03:45 PM
gingerbee's Avatar
mpg is very correct on water set epoxy make sure it's rated for that jb weld is. and it's very cheap and a good epoxy will last years +
closing off side fan hole? edisleado Air Cooling 4 January 21, 2010 03:36 PM
Fan Hole & Radiator Template Downloads Mnpctech Guides & How-to's 6 October 30, 2009 03:07 AM
Hole in antistatic bag SuperFriedFish Troubleshooting 11 August 5, 2008 06:06 PM
Hole Saw Question miggs78 Cases 11 July 14, 2008 04:37 PM
hole mounts on a 1900XT same as HD3870 maxxxxel Water Cooling 0 June 27, 2008 07:14 AM
