Old May 22, 2010, 05:07 PM
KaptCrunch's Avatar
Default DFI Jr X58 caps interfearence
Hk3 has issues with caps, don't want to bend caps tops to fit.
options slide the mounting bracket within block to allow clearance or mill groves for caps ends
Old May 22, 2010, 05:24 PM
martin_metal_88's Avatar
I think you will have to change your block my friend. Many X58 board have the same caps at the same place and it's the first time I see this issue.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old May 22, 2010, 06:21 PM
0o0 0o0 is offline
grab a dremel and trim it. Or get a non dfi board (not asrock either)
Old May 22, 2010, 06:53 PM
The board is not the problem. The water block is. Look at this GA X58 UD5. Samething. EVGA board also have the same caps at the same place. That the intel ref design.
http://images.bit-tech.net/news_imag...e-X58-UD5P.jpg
http://www.theinquirer.net/img/1737/evga_x58.jpg
http://en.expreview.com/img/2008/08/...eluxe_X58s.jpg
You see...all popular board that people watercool pretty often that have caps at the same place.
Ask for more
Martin_metal_88
Old May 22, 2010, 07:00 PM
KaptCrunch's Avatar
i'm good with it just giving a heads up for others.
Last edited by KaptCrunch; May 22, 2010 at 09:28 PM. Reason: turned WB to show what it looks like
Old July 21, 2010, 07:06 PM
KaptCrunch's Avatar
Default remedy
millled rescesses in cap area
Old July 21, 2010, 07:19 PM
Liu Kang's Avatar
First of all, you don't have the block installed properly... where are the springs, spacers and washers?
I've owned a few HK blocks, and they fit "snug" on all the boards I've tried (EVGA x58 micro, x58 LE and SR-2). The mounting holes on the LE didn't quite line up, but with the proper mounting hardware, I was able to angle the screw slighty in order to get it to line up with the spacer.
G'luck.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old July 21, 2010, 08:55 PM
KaptCrunch's Avatar
G'luck.
...installation is correct on my keyboard....lolz
oh a angled stud is very good on torsional load.....sorry but not in my books
hence milled out for to line up correctly not force twisting mounting hardware.
wait for next round of pic's for springs an see how it is done correctly
Old July 21, 2010, 09:21 PM
Liu Kang's Avatar
LOL, I'm not talking a 45 degree angle, I just mean it gives you that little bit of play you need to get it all lined up.
LK
Old September 5, 2010, 05:21 PM
KaptCrunch's Avatar
Default update some pic's
trimmed off the caps extra nibbs sticking out from bottom of MB so not to touch girtle plate with a toe nail clipper
the notched groves worked out perfect
for mounting hardward didn't use the supplied nylon washers, used the stand off's as stud's on back plate and used the nuts as jam nuts
windwithme's LGA 1156 review part5-DFI LANParty DK X58-T3eH9 Overclocking test windwithme Member Reviews 11 January 1, 2010 10:51 AM
windwithme’s Core i7 review Part 9-DFI LANParty JR X58-T3H6 Extreme power with mATX windwithme CPU's and Motherboards 8 July 16, 2009 04:26 AM
DFI LanParty UT X58-T3eH8 LGA 1366 Motherboard Review Comment Thread 3oh6 CPU's and Motherboards 10 April 7, 2009 04:02 PM
DFI is BACK!!! 632fsb done on DFI P35 T2R by Oskar Eldonko CPU's and Motherboards 14 June 21, 2007 09:40 AM
