  #21 (permalink)
Old August 10, 2011, 03:24 PM
KaptCrunch's Avatar
Originally Posted by codeman View Post
lmao, seriously... and a peltier on a chipset??? :P Dude, you installed the block wrong. They fit.
what don't fit its mounted already, just having wet spots with hot summer in winter was fine
well tell me why not with 64c on stock, when intel say 37c is the best put through
  #22 (permalink)
Old October 26, 2011, 08:35 PM
KaptCrunch's Avatar
halfway there
  #23 (permalink)
Old January 9, 2012, 12:01 PM
KaptCrunch's Avatar
Default double headed iwaki
rated 12v @ 2.5amps diapharm pump runs 20v no problem, motor kept close to ambiant
  #24 (permalink)
Old March 14, 2012, 02:12 AM
KaptCrunch's Avatar
got it back in service with updated thermal sealing peltier and home made VR copper block knocked off 30c operating temp from stock alu picks l8r . 7hrs crunching rez water 125F ambiant 75f
  #25 (permalink)
Old March 27, 2012, 02:14 PM
KaptCrunch's Avatar
Default mosfet cooling
here what i done for mosfet cooling a hunk of copper
  #26 (permalink)
Old June 14, 2012, 06:27 AM
KaptCrunch's Avatar
well seems my vapour locked peltier is working for last week we had afew hot shoggy days an no issues of condensation
  #27 (permalink)
Old October 25, 2013, 10:31 AM
KaptCrunch's Avatar
Default 3yr service
since I buy WB haven't done no cleaning only adding water and not replacing peg just water
using silver barb's
was hitting 75c so I opened to fine some grease clogging waterways
this WB is a RRT plating, still like new inside no etching or black
  #28 (permalink)
Old October 25, 2013, 11:02 AM
lowfat's Avatar
That is disgusting. What tubing were you using?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #29 (permalink)
Old October 25, 2013, 11:49 AM
KaptCrunch's Avatar
medical silicone tubing been 3-4yrs mixed with peg for rad out window in winter last while been just water
windwithme's LGA 1156 review part5-DFI LANParty DK X58-T3eH9 Overclocking test windwithme Member Reviews 11 January 1, 2010 11:51 AM
windwithme’s Core i7 review Part 9-DFI LANParty JR X58-T3H6 Extreme power with mATX windwithme CPU's and Motherboards 8 July 16, 2009 04:26 AM
DFI LanParty UT X58-T3eH8 LGA 1366 Motherboard Review Comment Thread 3oh6 CPU's and Motherboards 10 April 7, 2009 04:02 PM
DFI is BACK!!! 632fsb done on DFI P35 T2R by Oskar Eldonko CPU's and Motherboards 14 June 21, 2007 09:40 AM
