Old May 22, 2010, 10:53 AM
Default WC Unit for Raven Case
Anyone have a Raven RV-01B case and use water cooling? Just curious on models that are relatively compatible with this particular case design.
System Spec Peripherals: NZXT Kraken X42 CPU cooler | Zalman MFC3 fan controller | Steelseries Apex M800 kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakersDrobo FS 6.5TB Synology DS1515+ 15TB
Laptops: Asus G74SX-DH71 | Asus G752VY
Surface Pro 4 Core i7/256GB
Old May 22, 2010, 12:30 PM
Keltron 3030's Avatar
What do you want to know is compatible with it?
I know it can fit a 360 rad externally if that helps.
Old May 31, 2010, 10:57 AM
Oops! Forgot to check in on my query.
Yeah, I want to know if there's any particular models that are incompatible with the case's design. For example, I was toying with the idea of trying a Corsair H50 or Coolit ECO cooler. Not sure what you mean by a 360 radiator. Link?
Old June 2, 2010, 06:06 AM
steers's Avatar
Both the H50 and the ECO should work fine in the RV01, as you just need to mount the unit's radiator on the case's 120mm exhaust fan (I was going to say rear exhaust, but that's not exactly so with this case ), in pretty much any orientation. If you're thinking about actually putting together a water cooling setup in the Raven (read: not a single enclosed unit), it looks like you'll need to mount your radiator externally though.
Old June 2, 2010, 08:40 AM
Thanks, Steers. That's the info I was looking for. I was wondering about the vertical exhaust fan vs. the rear radiator cut out that is designed into the case. I need to find some pics of WC setups with the Raven. Will fire Bing up for a look-see.
Old June 2, 2010, 08:50 AM
steers's Avatar
Looks like it's indeed possible to mount a triple rad on the back of the Raven, but I'm not sure how much modification is involved. Here's a picture from a Raven buildlog I found:
Old August 8, 2010, 07:22 AM
Your case came with 4 brackets to do this. I'm just looking around for ideas before I do my raven.
Signal, did you end up WC'ing?
Old August 8, 2010, 11:23 PM
Is it just me, or are there some very serious issues with this mount??
Namely: How do you fit the GPU's (specially the rally long ones like 5970/480/470/5890)??
Old August 8, 2010, 11:27 PM
The case comes with a bracket to keep longer GPU's in place
FFFFFFFUUUUUUUUUUUU-
[FS] FS: Sg03 case/ Sony head unit odis172 Buy/Sell & Trade 23 February 15, 2010 02:34 PM
Silverstone Raven Case Review FreeKnight Member Reviews 3 September 5, 2009 06:11 PM
Silverstone Set to Launch Next Gen Raven Case RV-02 FiXT Press Releases & Tech News 10 July 27, 2009 09:56 AM
not enoguh screws in raven case? please help fast go flames go Cases 3 April 9, 2009 04:31 AM
