Old May 19, 2010, 01:38 PM
Dazmode's Avatar
Yeh, that pump will be better. Koolance or EK block doesn't matter, they are more or less the same.
Orange Build: Final Video
HTPC Build: Final Video
Old May 19, 2010, 01:50 PM
Dazmode's Avatar
Also, your 90 degree fitting 5/16OD, so you can NOT use compression part with 3/4OD tube (still ok as barb although).
New to Water Cooling fishingfanatic Water Cooling 4 April 30, 2010 09:36 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
