<~----> Need advice for a first time/extravagent WC setup. - Hardware Canucks
Old May 17, 2010, 12:07 AM
Default Need advice for a first time/extravagent WC setup.
So, I need some advice on a first time WC Setup. I've chosen the primary components that I believe will be good enough. Although I still need to know which fittings to get , and I would like some opinions and advice on how well you think this will perform.
Components:
VGA WB: NCIX.com - Buy Koolance VID-AR587 Full Cover CrossFire Ready Video Card Water Block - Radeon HD 5870 G1/4 - VID-AR587 In Canada.
CPU WB: NCIX.com - Buy Koolance CPU-360 LGA1366/1156/775/AM3 Universal CPU Water Block G1/4 Threads - CPU-360 In Canada.
MB WB: NCIX.com - Buy Enzotech EVX-58 Classified Sn Water Block for EVGA X58 3X SLI Classified Motherboard - EVX-58 Classified SN In Canada.
Pump/Res: NCIX.com - Buy Koolance RP-1000BK 5.25IN Reservoir & Pump Combo W/ Front LED Display G1/4 - RP-1000BK In Canada.
Rad: NCIX.com - Buy Feser One X-360 TFC Xchanger Triple 120MM Water Cooling Radiator G1/4 - 4260119641020 In Canada.
Crossfire fittings: NCIX.com - Buy Koolance Adjustable Dual VID Connect Nozzle for SLI or CrossFire Cards with One Slot Spacing - CNT-VDA2 In Canada.
I'm hoping to fit all this into a Corsair Obsidian 800D. As you can see I still need a few things. Some help would be MUCH appreciated, thanks.
Current state of Build:
Rig Specs:
EVGA x58 Classified Motherboard
Intel Xeon W3520 CPU @4.1 Ghz
6 GB (3x2GB) Corsair Dominator GT 2000 Mhz RAM
3 X XFX HD5870 XXX Edition Graphics Cards
Corsair HX1000w PSU
2 x Intel X25-M SSD's in RAID 0
3 x 2 TB WD Black HDD's for Files and Storage
2 x DVD Drives
Corsair H50 CPU cooler.
Old May 17, 2010, 06:17 AM
Dazmode's Avatar
Choose size of your tubing first and it will determine size of your fittings to match it.
Orange Build: Final Video
HTPC Build: Final Video
Old May 17, 2010, 07:21 AM
AmuseMe's Avatar
Im PMing you right now...
DEAD CA$H
Old May 17, 2010, 02:58 PM
Musabi's Avatar
If you want the X-Changer you better buy quickly, they aren't being made by Feser anymore.
Tags
crossfire , fittings , koolance , water block , water cooling
First time watercooling, setup OK? TALON Water Cooling 3 August 1, 2009 01:46 PM
First time water cooling, need advice. Blam Water Cooling 56 July 20, 2009 05:54 PM
Overclocked for the first time.. need some advice MrFoxx Video Cards 11 May 17, 2009 11:03 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
Help with First WC setup... time sensitive, it's for christmas! fynd Water Cooling 19 December 22, 2008 07:55 PM
