Old May 13, 2010, 12:56 PM
Default Just bought 2nd hand pump, how do I remove the reservoir
Hi,
I have just got a second hand Innovatek HPPS pump and it has a small black res attached to the front of it, I was wondering how to remove it if possable?
I can twist the black res off the large disc adapter but tht adaptor stays on the pump and just seams to turn and turn?
Any ideas please anyone?
Old May 13, 2010, 01:59 PM
Jackquelegs's Avatar
A picture of your pump would help. I can't really make out a res in the ebay pic
Iapetos
Zephyranthes
Old May 13, 2010, 07:36 PM
JD JD is offline
It's black and stuck onto the "front" of the pump where you'd expect to find the intake port. Thus why you see that barb up pretty high and a yellow cap of sorts on the very top.
I believe the adapter is meant to stay. Eheim pumps don't typically have G1/4 threads on them which is what typical barbs for watercooling use.
More pictures would definitely be helpful though.
Old May 18, 2010, 08:47 AM
see the disc that is stuck on the res in the last pic.... ... is it possible to remove it?
Cheers for you time....
Old May 18, 2010, 10:14 AM
JD JD is offline
Hmm, looks like it might be integrated into the reservoir. My guess would be that you need to find the stock "top" for the pump. However maybe somebody with some Eheim experience could chime in.
Any reason why you just don't want to use it as-is? Most people pay extra to have the reservoir attached to the pump, as it makes the loop simpler and ensures that the pump always has fluid.
Old May 18, 2010, 11:03 AM
KaptCrunch's Avatar
looks to be a innovtek product HPPS not Eheim stock parts.
HPPS rez looks if there 3 parts to it
Old May 18, 2010, 11:08 AM
I feel like a bit of a plonker now, it just needed a bit of extra force to push it off, I was worried I was going to break it. As you can see, just a double 'O' ring gasket holding it in place.
Wierd thing is that it seems to be a 1/2" inlet, 1/8" outlet, I expected 1/4" & 1/8" but that's life I guess lol.
Cheers for helping.
Old May 19, 2010, 07:40 AM
KaptCrunch's Avatar
np Darfyddi
think it this way, if not asked questions prior to test.....who's the dummie at test time.
glad to help
note great snap shots but a lil to large on screen here, size'm down a bit ;)
remove tim stain from cpu? BobbyLou CPU's and Motherboards 6 January 26, 2010 11:51 PM
HD 5870 Size ? = Remove HDD Bays JORD4N Video Cards 2 October 3, 2009 05:54 PM
I can't remove my side panel... Slinger Troubleshooting 5 February 29, 2008 11:26 AM
Do i need to remove V-droop with the voltage dampner magictorch Troubleshooting 1 January 19, 2008 07:16 PM
How to remove the air inside tube? francois methot Water Cooling 18 August 6, 2007 07:23 AM
