Old May 9, 2010, 07:42 PM
JD JD is offline
Though just to let you know, MCP355/DDC3.2 aren't that quiet IMO. My MCP355 is the only audible thing in my PC currently. It's not annoyingly loud though, but if you're going for silence, it's far from it.
Old May 10, 2010, 01:01 PM
That's so true. Especially with 2 MCP355s in one machine will generate quite a bit of noise.
If you want the silence, MCP655 is the way.
Old May 10, 2010, 04:00 PM
AmuseMe's Avatar
I have a modded Swiftech Apogee Drive. Which was a pump/CPU block. I stripped it down and it is identical in looks and performance as an MCP350. With the mod the MCP350, is pushing 18V just like a MCP355. I dont find it loud at all.
DEAD CA$H
Laing DDC dual bay reservoir. Lima Water Cooling 0 February 12, 2010 12:11 PM
DD Dual bay res back in stock! Sniper Water Cooling 3 November 21, 2008 10:42 AM
Mediasonic Dual Bay Raid (HUR1-SU2FWB) jgerber Storage 4 November 7, 2008 11:29 AM
looking for XSPC Laing DDC cryptospartan Buy/Sell & Trade 0 May 25, 2008 08:33 PM
