Old May 8, 2010, 11:21 AM
Default MO-RA 3 coming soon
Rico's finally got these monster's out
More pic's at Hardwareluxx.de
http://www.hardwareluxx.de/community...4-post915.html
And a few sidenotes, the chicken wire radiator grill looks disappointing, but there will be an option to buy the radiator itself. You could always make your own fan shrouds
The new specs
- Lower fin density (no actual comparisons yet)
- 4 parallel tubes vs the 3 in the Mo-Ra 2
- Available in white and black
- Has spacings for 9x120mm fans, 4x140mm fans, and a new monster 9x140mm fan mo ra coming in June
Also, there are rumors about a new line of normal radiators from Watercool, i.e. 360, 420, etc
Old May 8, 2010, 12:44 PM
Dazmode's Avatar
Radiator market heats up this year.
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old May 8, 2010, 12:46 PM
Jackquelegs's Avatar
Fantastic. Hm...might be investing in one of those for summer.
Also..getting ready to pull the trigger on the Non-reference EK 5870 block in dazstore. Only Canadian shop to carry it apparently..
Iapetos
Zephyranthes
Old May 18, 2010, 09:41 PM
biff's Avatar
hmmm appears to be AL internals.... Any idea of the cost of these? Really thinking at doing a remote rad/pump setup once I get in my new house to move the bulk of the noise away.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old May 19, 2010, 08:03 AM
MpG's Avatar
MpG MpG is offline
I was given to understand they use cu tubing with al fins, which makes mixed metals a non-issue as far as the rad is concerned. And they seem to be taking steps to address the early model's shortcomings - the high fluid restriction, the high airflow restriction, and the bloody-awkwardness of mounting it anywhere. I suspect it'll still take second-place to a trio of triple rads from any of the current leading manufacturers, although the convenience will obviously be a big attraction.
Old May 19, 2010, 08:53 AM
KaptCrunch's Avatar
Restricted Poster
seening it as a great for benching or space heater with gpu's,i7 setup, just add fans
Coming soon Dan New Builds 16 April 15, 2010 05:11 PM
F.E.A.R. 3 is coming Killswitch Gaming 5 April 14, 2010 06:34 AM
XMAS IS COMING!! What do YOU want?? chouchou Off Topic 148 December 21, 2009 09:37 PM
i7 build coming soon HalifaxJ New Builds 3 April 15, 2009 10:33 PM
amBX Coming Soon? Thund3rball Press Releases & Tech News 8 January 9, 2008 08:07 PM
