Old May 6, 2010, 07:17 PM
bottle's Avatar
Default Weird smell from radiator
Well I recently drained and refilled my loop.
And on top of that OC'ed my E8400 to 4.2GHz.
Now here's the thing, when I put the CPU on load, it gives off quite a bit of heat (that's to be expected) but with it a weird smell. I'm not quite sure what it is.
Any ideas? or perhaps this is normal. Using an MCR320.
Thanks in advanced guys.
Old May 6, 2010, 08:54 PM
lowfat's Avatar
What smell? My system smelled like burned electronics for the longest time. I was also using an MCR320.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 6, 2010, 10:04 PM
bottle's Avatar
Hmm, it's really hard to explain. It's sort of a burnt smell I guess, but it's more a... chemical-ish smell. It's really hard to explain.
Almost like how it smells to get a new computer. Except mine is 2 years old already!
Peculiar, but can any MCR320 users comment?
Old May 6, 2010, 10:08 PM
You may have spilled a little coolant while draining and it is on a hot component. If it's only light spillage, it will go away in time. It wouldn't hurt to chech and double check for a leak no matter how tiny it may be.
Old May 6, 2010, 11:04 PM
MpG's Avatar
MpG MpG is offline
The MCR's are usually pretty good for being flushed out, so aside from a little dust, there shouldn't really be any scent. What are you using for coolant? A lot of additives have glycol, which has a mild, but distinctive odor to it.
Old May 6, 2010, 11:28 PM
bottle's Avatar
I'm just using standard distilled water in some Primochill LRT tubing with the built in biocide.
What's weird is that I can really only smell it when I have my new OC on, with my old 3.6 it wasn't quite a problem. Perhaps it's too much heat?
I've been trying to find a leak too, but no luck as of yet.
Likewise, when my computer is idling, there's only a very slight hint of the smell, it gets strong as more heat is being transferred.
As for going away with time.. it has been just over a week, I would think it would stop smelling by then.
Really awestruck actually, just worried if I should be worried or not!
Old May 6, 2010, 11:30 PM
MpG's Avatar
MpG MpG is offline
Can you hear anything around the socket area? Maybe a very faint popping/crackling noise?
Old May 6, 2010, 11:37 PM
bottle's Avatar
No abnormal noises to report.
If it helps, I did only notice it after doing a full break down and rebuild due to changing my case (P182 - 800D)
Think it may just be the natural case odors coming out through the radiator? Since it is mounted inside and all.
Old May 6, 2010, 11:39 PM
MpG's Avatar
MpG MpG is offline
Yeah, a new case could definitely cause that, and an increase in case temps could encourage it. If that's all it is, should go away in time.
[WTT] radiator and a pump anabioz Buy/Sell & Trade 5 October 28, 2009 04:33 PM
POP and burnt smell blackettle Troubleshooting 16 March 23, 2009 02:27 PM
Radiator? nick_black Water Cooling 8 February 12, 2008 08:24 PM
Smell of Smoke + PC = Bad BALISTX Off Topic 7 June 7, 2007 11:28 PM
Motorola's mobile smell-o-phone Supergrover Press Releases & Tech News 2 April 14, 2007 08:33 AM
