Old May 3, 2010, 11:16 PM
Default my water cooling worknig blog
alright finally decided to go with water cooling been doing quite a bit of research and getting advice from expert such as daz and HWC guys been great help thus far
i ordered parts slowly 1 by 1, i am taknig my time building this thing =P
alright first of is the case mod so i can fit this gigantic radiator
this is the part i have to cut to fit the radiator (didn't do a good job here as i am really lack of tools
and ha finally time to fit the rad
alright next up is the GPU water block
stripped apart, i actually ran into a little bump during the process, i stripped one of the back screws but finally manage to take that out too
and then applying the thermal pads
and finally the final product
i ll try to keep it updated much as possible when ever i have time and when ever the new parts comes =P
Old May 4, 2010, 06:21 AM
Sushi Warrior's Avatar
Size your pics WAAAAY down. 800x600 would be nice.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old May 4, 2010, 07:21 AM
haha sorry about that, i use msn photo storage, trying to find the best size
too bad they dont have 800x 600 =(
anyway size fixed
Old May 4, 2010, 07:24 AM
Looking good! EK makes a sexy WB. What case is that?
Old May 4, 2010, 07:36 AM
it is the thermaltake armor+ vh6000bws
when everythng is stripped apart XD
i take them apart to paint them, have yet to put them back together all the mod 's been done
Old May 4, 2010, 06:25 PM
alright here is the reservoirs
anyone got any idea wut color of coolant i can use to match this reservoir ?
Old May 4, 2010, 06:42 PM
Dazmode's Avatar
Nice work on GPU block installation!
This rad just fits barely, make sure youy lift it to allow air to escape or get in.
Orange Build: Final Video
HTPC Build: Final Video
Old May 4, 2010, 06:43 PM
Dazmode's Avatar
Green @|@
I need one of those myself!
Old May 4, 2010, 06:56 PM
Yah the green looks great! I've got the red, but the led's don't seem to be working, and I don't have the time to take it apart right now. Oh well eh, I just stuck a ccfl and a 5 uv led unit next to it. Mine looks decent with purple fluid, I'm think the yellow would go good with your reservoir, won't take away from the green so much, and still provide some contrast.
Old May 4, 2010, 09:07 PM
yah i was thihknig using a green coolant might cover up the UV light of the holix
but i guess have to try it in order to see which one works out better =P
Cycling blog for noobs from a noob. The MAX Off Topic 2 September 15, 2009 04:27 AM
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
