Old May 5, 2010, 03:18 PM
hey for my setting the flow will most likely be
res -> pump -> CPU -> GPU -> rad -> back to res
is that fine or is it better to go from res -> pump -> rad the cooling parts?
Old May 5, 2010, 03:45 PM
gingerbee's Avatar
it really does not matter that much but i always run res-pump-rad-cpu-what every block- back to res . jmo
Old May 5, 2010, 04:12 PM
alright thanks,
i guess i ll go for orginal flow then res to pump to cpu
other wise i ll have a arkward cross over tubes
Old May 5, 2010, 11:26 PM
alright in the mean while waiting for next shipment to arrive from daz here is some update
first two pictures is what i got from flushing the radiator
the water is clear, but then there are bits and pieces coming out from it, maybe i shoyld flush it some more later @_@
then the rest is just a general view of how the whole layout is going to be
feel free to give me some advice and if u have any suggestion please feel free to let me know
Cycling blog for noobs from a noob. The MAX Off Topic 2 September 15, 2009 04:27 AM
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
