Originally Posted by Dazmode Guys I'm tried newest Apogee XT block and distance between inlet outlet is very small. I can fit 3/8" compression , but not 1/2" compression fitting.
I think I have seen somewhere that you can flip inlet part to make longer distance between holes....
Can anybody point me to any thread or review about this issue? |
My apologies for resurrecting a thread that's been dead for 7 months, but it seemed to be the most relevant to the question I've got...
When you said that 3/8" compressions fit, what was the tubing outer diameter, 1/2" or 5/8"? (I'm trying to figure out if I need to look into angled fittings for this block or if I can just use standard compression fittings.)
