Old April 30, 2010, 03:01 PM
Rison's Avatar
Default Watercooling F@H Farm
Ok, I have a few things on order already and need to pick up a few more things.. but what i'm looking to do is watercool my folding farm.
Right now, I have an i7 860 (cpu1), i7 920 D0 (on the way, cpu2), Q9550 (cpu3) and two GTX 280 (w/ EVGA waterblocks)
I'm looking to basically mount the watercooling externally of the three cases / open air workbenches - and looking for some inspiration.
I have the res on order (from daz) and have one MCR320, and all the waterblocks (well.. we will say I have them, but don't need help picking those out) I have one MCP 655 coming from a HWC user.
Question - could I do a loop like this:
Pump > cpu1 > cpu2 > cpu3 > Rad > gpu1 > gpu2 > Rad #2 > Res > back to pump
it would all be one the same plain (as in, the same desk height) would the pump be enough to go through that many devices? I am unaware if there is a distance issue with the pump in a closed loop.
Failing that, i'll separate the GPU and CPU loops.
The second rad i'm thinking about getting is a Feser X-480.. that should do the trick.
Any hints or tips/tricks on what i'm looking to do would be helpful.. i'll have a build log in a few weeks when it's complete.
I'll learn to manage my anger, when people learn to manage their stupid.
Old April 30, 2010, 08:41 PM
Dazmode's Avatar
I can not say I know for sure, but my gut feeling you will need second radiator with good fans for this, and possibly two pumps in series if restriction will be too high.
Push/pull fans on rads will help too (fans on both sides of radiator).
Orange Build: Final Video
HTPC Build: Final Video
Old May 1, 2010, 09:24 PM
JD JD is offline
Should of just got one of these: MagiCool XTREME NOVA 1080 ( 9 X 120mm) Radiator Products Model: MC-XTREME1080 [MC-XTREME1080] : Performance-PCs.com, ... sleeve it and they will come
But I'd say split up the GPU and CPU loops. Otherwise I think you'd need something stronger than the MCP655, probably some Iwaki pump.
My time folding farm martin_metal_88 New Builds 35 December 26, 2009 10:43 PM
Folding Farm and OC Lab MarkOne Case Mods, Worklog & Gallery 51 November 30, 2009 10:02 AM
Farm Setup Help Shredder HardwareCanucks F@H Team 5 June 6, 2009 08:08 PM
Wanted - Folding Farm Motherboard CasheKicker HardwareCanucks F@H Team 8 March 7, 2009 06:05 AM
Lcdguy's Folding Farm :) lcdguy HardwareCanucks F@H Team 32 November 20, 2008 04:40 PM
