Old November 30, 2007, 07:01 PM
I did notice this last night when I was window shopping/.... Did you know they are coming out with a dual rad version within a few days.... So i have heard!!!!! Wonder if its identical except for the rad size??? Thats whats holding me back.......
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old November 30, 2007, 07:10 PM
Cptn Vortex's Avatar
Well, the dual RAD is for sale, but it is not in a Kit yet. It is called the MCR220-QP Res.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old December 1, 2007, 06:07 PM
its called the h20 120 compact extreme... avaliable in a few days... I have photos... pretty neat.....
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old December 2, 2007, 01:35 AM
JD JD is offline
Post em then...
Old December 2, 2007, 07:46 AM
Swiftech :: View topic - h20 120/ dual rad?
try that...
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old December 2, 2007, 11:05 AM
JD JD is offline
Looks good. Should get better temperatures than the single 120mm as that really doesn't seem too great to me.
Old December 2, 2007, 02:48 PM
Ou, that's really nice. Now all they need to do is build a Stealth Drive, or some other form of GPUblock/pump combo, so I can use this for GPU only cooling. Does anyone know if these Rads must be vertically mounted?
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Old December 2, 2007, 03:12 PM
I don't know about the rads being mounted horzo.... I dont know really if it effects the resivour part of it.... but I am curious if u could use this for just the gpu's.... really would it hurt anything?? just bury the apogee pump somewheres and let her go?? I know its a cpu block, but hey??... whatcha think?
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
  #19 (permalink)
Old December 2, 2007, 03:14 PM
Or, wonder if you can rig the Apogee block up to a 8800.....where there is a will, there is a way.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Swiftech Apogee GT question Vinnie Water Cooling 8 February 23, 2008 03:43 PM
Hard to find HIS 3870 ICEQ3 or Instock 3850 ICEQ3 Turbox BALISTX Video Cards 7 January 25, 2008 09:51 PM
Compact Watercooled Gaming Rig! (planning stages) Cptn Vortex Case Mods, Worklog & Gallery 9 January 11, 2008 09:57 PM
Help with Swiftech H20-120 kit Varroa Water Cooling 19 January 4, 2008 09:43 AM
Swiftech APOGEE Drive JD Water Cooling 14 August 16, 2007 10:35 PM
