Old April 25, 2010, 04:09 AM
Dashock's Avatar
Default When should u change your loops liquid?
Have been using Swiftech's liquid with distilled water now since last July i believe. How often should i be changing the water? Cheers.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old April 25, 2010, 06:19 AM
I change mine every 4 months, Needed or Not.
In the pre mixed set-ups, I think your safe for 6 months plus, Just keep an eye out for gunk in the lines and Res.
Distilled Water and PT nuke, Very easy to work with.
Old April 25, 2010, 11:38 AM
Dazmode's Avatar
I change between 6 and 9 months. If I change color or brand I disassemble loop completely if I use same coolant mix I just give loop double or triple rinse with distilled water.
Orange Build: Final Video
HTPC Build: Final Video
Old April 25, 2010, 11:53 AM
gingerbee's Avatar
6 to 9 months for me too.
Old April 25, 2010, 01:34 PM
HaDeS
Guest
Posts: n/a
is it a good idea to trim the water lines at the same time?
Old April 25, 2010, 01:36 PM
Dazmode's Avatar
What do you mean?
Old April 25, 2010, 01:48 PM
gingerbee's Avatar
if you mean replace, well i use thick wall tubing so i normally change it once a year but it's really up to you
Old April 25, 2010, 06:06 PM
JD JD is offline
Well I find my PC doesn't stay on the same components for longer than 6 months
So it gets drained often enough.
Old April 25, 2010, 06:09 PM
MpG's Avatar
MpG MpG is offline
If you're talking about trimming the imprinted ends off the tubing, that's a judgment call. If I have tubing length to spare, I usually will, since I have a gut feeling that the clamping isn't as tight the second time around. But I very much doubt that it's necessary, as long as you go through the standard leak-testing after re-assembling everything.
Old April 25, 2010, 06:11 PM
Dashock's Avatar
yea theres no gunk or anything i guess ill be rinsing out with distilled water thanx guys.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
anyone know of a Liquid acrylic filler? Shadowmeph O/S's, Drivers & General Software 3 June 6, 2009 10:18 AM
Fruity Loops Studio Sounds shayan288 Off Topic 0 January 24, 2009 02:29 PM
Two Loops? Infiniti Water Cooling 10 June 16, 2008 09:32 AM
Suggested loops and Pump silverchair Water Cooling 6 February 23, 2008 09:17 AM
Fruit Loops r00tman CPU's and Motherboards 13 May 4, 2007 07:47 AM
