Old April 24, 2010, 08:04 AM
gingerbee's Avatar
yup coolant is the way to go i throw a bottle on almost every other order for myself it was said before 20$ is a happy computer
EDIT nothing is full proof but my point is that after you spend 2000G on a machine is 20 bucks for good coolant a big deal?.
Old April 24, 2010, 08:09 AM
Dazmode's Avatar
I can't even count how many times I spilled distilled and more often Feser One all over my parts including power supply. I have never had more patience then 15 minutes after some paper towel clean out. (This is not invitation to do the same )
I'm sure if leek will take place unnoticed, distilled or non-distilled or whatever... you get toasted.
Orange Build: Final Video
HTPC Build: Final Video
Old April 24, 2010, 08:26 AM
"Quote This..."
My leak went unnoticed for days. It wasn't until I saw the reservoir was getting low that I went hunting for it.
Black belt in CAPS LOCK.
Old April 24, 2010, 10:17 AM
lowfat's Avatar
YouTube - Feser One F1 Cooling Fluid Non Conductive Teste
YouTube - Challenging the "Feser Conductivity Test" Video
YouTube - PT QuickClips - Fun With Coolant
Watch these videos. First one is from Feser. The other are done by Petra. As you can see, Non conductive coolants are a joke. You really are wasting your money if you are buying in to the whole non conductive hype.
First liquid cooling system - advice? Kartner Water Cooling 14 April 23, 2010 07:01 PM
TEC liquid cooling. Overclocker~4.1 Water Cooling 14 September 24, 2009 07:16 PM
Dry Ice and Liquid Cooling? CanadaRox Water Cooling 13 December 27, 2008 07:27 AM
...liquid metal instead of water! francois methot Water Cooling 15 July 20, 2008 02:17 PM
Fear of Liquid Cooling Beermaster Water Cooling 29 June 4, 2007 11:14 AM
