Old April 22, 2010, 08:45 AM
Dazmode's Avatar
Default NEW REVIEW: Flow Test
Here is another mini-review, where I checked for myself what is really happening when speed settings changed on Swiftech 655-01 pump.
Some good and some bad news here...
Water cooling Review. Swiftech 655 / D5 speed influnce of water cooled loop temperature
Orange Build: Final Video
HTPC Build: Final Video
Old April 22, 2010, 09:34 AM
SugarJ's Avatar
Any chance of testing flow rates with 1/2" vs. 3/8" tubing?
Old April 22, 2010, 09:39 AM
Dazmode's Avatar
I will put request on my list. RIght now I will do multi block test on my i7 gaming rig that has 6 blocks installed to see if that makes any difference.
Old April 22, 2010, 11:10 AM
Linus's Avatar
This has been done by the legendary Cathar. I can't find the link immediately, but I can summarize for you:
Unless you go down to 1/8" tubing, the difference cannot be measured unless you have a controlled environment and fairly accurate equipment.
We're talking on the order of 1 to MAYBE 2 degrees from 1/2" to 1/4" and the difference between 1/2" and 3/8" is less than 0.5C as I recall.
Please note: I am not here to provide official NCIX support on these forums.
For faster (and official) NCIX service please contact our customer care team at www.NCIX.com (Canada) or www.NCIXUS.com (USA)
Heatware: http://heatware.com/eval.php?id=25647
Old April 22, 2010, 11:19 AM
SugarJ's Avatar
Thanks Linus, but I was more interested in the flow rate than temps. Mostly because of Daz's max flow rate of around 1 GPM.
Old April 22, 2010, 11:32 AM
MpG's Avatar
MpG MpG is offline
Yup, could have predicted that outcome. And this is all in the sub-1gpm part of the cooling curve, where any differences would be most pronounced.
THIS is probably the thread you're talking about, Linus. Definitely a good read.
Old April 22, 2010, 12:21 PM
Dazmode's Avatar
I wonder how many people have systems with 2 or more GPM pump power?
Old April 22, 2010, 12:29 PM
AmuseMe's Avatar
I'm waiting on a custom RD-30, well I'm waiting on the guy to get them done. 5.3GPM
Old April 22, 2010, 02:14 PM
Dazmode's Avatar
With 6 blocks in the system starting flow is 3.2LPM from 3.8LMP with single CPU block at max setting (5).
Old April 22, 2010, 08:15 PM
MpG's Avatar
MpG MpG is offline
Three DDC 3.2's in series, running about 2.5gpm right now. I keep meaning to convert them down to 3.1's, but have been too lazy to pull the loop apart.
HDD fails S.M.A.R.T. short test, but passes long test? frontier204 Storage 10 May 19, 2011 04:10 PM
windwithme's LGA 1156 review part5-DFI LANParty DK X58-T3eH9 Overclocking test windwithme Member Reviews 11 January 1, 2010 11:51 AM
TTIC Micro Flow Intel S775 Water Block Performance Review @ Madshrimps SKYMTL Reviews & Articles from the Web 0 September 4, 2007 05:39 AM
Gskill F2-6400CL4D-2GBHK test review. Wankerfx Member Reviews 11 May 23, 2007 05:50 PM
