Old April 22, 2010, 08:37 PM
astrodanco's Avatar
Originally Posted by Dazmode View Post
I wonder how many people have systems with 2 or more GPM pump power?
EK-D5 Dual Top here at 8.2 LPM.
Core i7 920 (D0) @ 4.0Ghz, P6T Deluxe V2 (0901), 12GB Corsair CM3X2G1600C7 @ 1600 7.7.7.20 2T, ATCS 840, Antec TPQ 850, Radeon 4850, TMS-200 + TMS-EB200, EK Supreme HF, EK-D5 dual top, 2x MCP-655-B, MCR-320, 6X Skythe D1225C12B5AP-15, Durelene tubing. Obviously not a gamer as you can tell by the low end video card.
Old April 23, 2010, 06:53 AM
Dazmode's Avatar
Don't serial setup give only 30% boost, not doubles the flow?
Orange Build: Final Video
HTPC Build: Final Video
Old April 23, 2010, 07:46 AM
scruff's Avatar
Good morning Daz , I agree with you dual pumps in series should give onlly about 25% to 40% increase in flow depending on the loops, but they will definatelly give you a lot more head pressure to over come friction losses in multiple water blocks (large loops)
Old April 23, 2010, 02:49 PM
MpG's Avatar
MpG MpG is offline
It doubles the P/Q curve vertically (head pressure), but does nothing horizontally (flow). Add to that, the fact that flow restriction increases exponentially, and you'll never actually double your flow by doubling your pump. But the flow-biased curve of the D5 does better than many pumps when put in serial, so I don't think I'd be surprised to see gains in the %40-50 region when run in serial.
Old April 24, 2010, 08:17 AM
Dazmode's Avatar
Here is same test results for multiblock i7 systems. I don't run it overclocked, so entire setup almost choked when I put it to 4ghz. Nevertheless the picture I've got was slightly different from the first test.
Full text is here
HDD fails S.M.A.R.T. short test, but passes long test? frontier204 Storage 10 May 19, 2011 04:10 PM
windwithme's LGA 1156 review part5-DFI LANParty DK X58-T3eH9 Overclocking test windwithme Member Reviews 11 January 1, 2010 11:51 AM
TTIC Micro Flow Intel S775 Water Block Performance Review @ Madshrimps SKYMTL Reviews & Articles from the Web 0 September 4, 2007 05:39 AM
Gskill F2-6400CL4D-2GBHK test review. Wankerfx Member Reviews 11 May 23, 2007 05:50 PM
