  #31 (permalink)
Old May 19, 2010, 01:08 PM
Originally Posted by Dazmode View Post
Try $40 garden players, not $10 ... big difference.
lol i saw the one that is 60% off and it's 25 years warranty, so i thought it would be good enough .... do you mean the straight ones or the curved ones?
  #32 (permalink)
Old May 19, 2010, 01:10 PM
gingerbee's Avatar
wasting my types spend the 40$ bucks you want too. go and talk to someone at a hardware store guys this is beyond silly to me. done do your self a favor and go into homehardware or check dangerden good luck to you
  #33 (permalink)
Old May 19, 2010, 01:19 PM
Dazmode's Avatar
I use curved Fiskars.
Orange Build: Final Video
HTPC Build: Final Video
  #34 (permalink)
Old May 19, 2010, 01:30 PM
gingerbee's Avatar
your the only water cooling shop that recommends using 40$ cutter sorry but i strongly disagree even dangerden says to use vinyl tubing cutter ( like they do in all there vids ) i choose to disagree sorry m8
  #35 (permalink)
Old May 19, 2010, 01:35 PM
Dazmode's Avatar
I don't recommend anything actually, I just use what I have at home and it works for my own sake. I also can say that any sort of knife have never worked for me... Surely dedicated tube cutter will work great, no argument here.
  #36 (permalink)
Old May 19, 2010, 01:36 PM
hmmmmm cool down guys! ok i will check out the hardware store maybe under garden variety too, i will ask them which one is better, maybe they can demonstrate to me so that i can get the results i want. Thanks all
  #37 (permalink)
Old May 19, 2010, 01:42 PM
gingerbee's Avatar
off course they can what do you think they use to cut the tubing there selling you. this is how they work just like mine do sorry if i seem a little over the top but to spend 50 bucks to get straight tubing is down right nutz YouTube - Cutting PVC PIPE cutter, PIPE Fitting, Plumbing tool, PVC tubing cutter
  #38 (permalink)
Old May 19, 2010, 01:48 PM
Dazmode's Avatar
With my A.D.D. and no-patience problems this is no go. It takes split second with my Fiskars to adjust tubing!
  #39 (permalink)
Old May 19, 2010, 03:09 PM
gingerbee's Avatar
i am not sure what you mean by adjust, cutting it to different length's well it's very easy. they do it in this video nice and slow to show you most of us just use them like any cutting tool.
jsut go adn see what they cut the tubing with yourself.
  #40 (permalink)
Old May 19, 2010, 03:22 PM
El_Fiendo's Avatar
Heh, I just ran a new loop two nights ago and all I used was a utility knife I had lying about.
Pushed the tip in until it broke the inner edge of the tubing, and then I rotated the tubing with my other hand and I had my cut. They aren't perfectly precise laser-like cuts, but they really don't need to be.
[WTB] blue ray movies ( will be updated with more from time to time) kyle_L Buy/Sell & Trade 3 September 2, 2009 04:20 AM
First time watercooling, setup OK? TALON Water Cooling 3 August 1, 2009 01:46 PM
Is WaterCooling for me? arekieh Water Cooling 10 October 20, 2008 05:50 PM
Watercooling Help EDMCR Water Cooling 24 August 3, 2008 07:24 AM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
