  #21 (permalink)
Old May 7, 2010, 08:03 PM
Originally Posted by Dazmode View Post
No I didn't mean you need poor water into part. I tried to say that when water start going trough the system you get air pockets here and there and you need to run system for few hours to get rid of air taht needs to be trapped only in your reservoir. Shaking and tilting case helps speed up the proces.
Ahh... i c.... that's true... the tubes used to have air bubbles... now it's solid... so... does the res needs to be filled above the "slope" thingy? wouldn;t air bubbles trapped in the corner there? or do i have to tilt it at an angle?
  #22 (permalink)
Old May 7, 2010, 08:09 PM
Dazmode's Avatar
After day or two it will all gone. I just have no patience at all, so I "help" with tilting computer randomly and tapping on radiator, slowing down and accelerating pump, squishing tube.... That is just my voodoo-magic ritual, not a standard procedure by any means.
Orange Build: Final Video
HTPC Build: Final Video
  #23 (permalink)
Old May 7, 2010, 08:28 PM
gingerbee's Avatar
Yes it is i do it all the time hell got my last water cooled oc computer setup just yesterday and it took a whole 6 hours testing and all. and at op yes i run my setup and it's just me cause like you i fear heat
res-pump-rad-cpu block-res
  #24 (permalink)
Old May 10, 2010, 07:23 AM
LOL... yeah i saw your youtube video for filling ... i saw you squeeze the tubes while you fill.. i think i did it too.ahhaa i didnt listen to the video cz i was at work at that time... now the bubbles are gone and they are quiet!! haha... which btw Daz, check your PM, i want to order some parts from you and start to build my first watercooling!!!
ahh cool cool... i willl try that looop!
  #25 (permalink)
Old May 19, 2010, 10:47 AM
hey guys,
what do you guys to cut those tubing? Daz recommended garden pliers? i bought this bypass prune from canadian tire and tried to cut some unused tube (1/2" ID 3/4" OD), but they came out not straight, i tried couple of times and same result...
Got this one:
Fiskars Power-Lever Bypass Pruner | Canadian Tire
  #26 (permalink)
Old May 19, 2010, 11:10 AM
gingerbee's Avatar
I just use tube cutter there about 5 bucks from any hardware store. http://www.traderscity.com/board/use...e-cutter-1.jpg
when you water cool as much as i do these things save so much time.
better pic always straight cuts too never had a bad cut at all. 3 water cooled systems this month on top of my two.
  #27 (permalink)
Old May 19, 2010, 11:20 AM
oh.. thanks.... i tried to search it in canadian tire and these came up....
tube cutter Search results | Canadian Tire
Doesnt look like the one in the pic you showed me though...
  #28 (permalink)
Old May 19, 2010, 11:25 AM
gingerbee's Avatar
ya canadiantire does not seem to carry it i think because they don't sell vinyl tubing by the foot what your looking for is vinyl tubing cutters any hardware store that sells tubing by the foot will have them. hope it helps
  #29 (permalink)
Old May 19, 2010, 11:32 AM
... i c... so is this ok? this is the cheapest i could find in homedepot/home hardware/rona... 7bucks....
Home Hardware Product Details
Thanks a lot man!
  #30 (permalink)
Old May 19, 2010, 12:58 PM
Dazmode's Avatar
Try $40 garden players, not $10 ... big difference.
[WTB] blue ray movies ( will be updated with more from time to time) kyle_L Buy/Sell & Trade 3 September 2, 2009 04:20 AM
First time watercooling, setup OK? TALON Water Cooling 3 August 1, 2009 01:46 PM
Is WaterCooling for me? arekieh Water Cooling 10 October 20, 2008 05:50 PM
Watercooling Help EDMCR Water Cooling 24 August 3, 2008 07:24 AM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
