Old May 5, 2010, 12:14 PM
Dazmode's Avatar
Home Depot sells 1/2 PVC tube in plumbing section. More likely Canadian Tire has it too. Not sure if that cheap option...
Orange Build: Final Video
HTPC Build: Final Video
Old May 5, 2010, 12:17 PM
AmuseMe's Avatar
Originally Posted by t_mo_t View Post
***update***
Someone here in HWC wants to trade his watercooling gear for my eVGA 780i + cash... he just sent me his swiftech 320, 655 speed-controllable, swiftech res (v1, no hole at the bottom), swiftech apogee gt, DD CPX-1. I wont be using the cpu block, but i want to test the rad,res, and 655 first.. is it ok if i just loop them and see if there's any leak or something? Do i really need to get a tubing or garden hose would be fine? Does canadian tire sells 1/2" ID garden hose?
Thanks guys
I personally would just make a closed loop with the tubing you will be using for water cooling. Just make the pump push through all the componants (outside the case!) and see if there are any leaks. Just use distilled water
Old May 5, 2010, 12:19 PM
thanks Daz.. PM'd ya
Old May 5, 2010, 12:22 PM
Yah... i think i will be doing res->pump->rad->res.. will that be fine?
Old May 5, 2010, 02:17 PM
Yep, just make sure the res is above the pump, so that gravity fills it, you don't want to turn on a dry pump.
Old May 7, 2010, 08:49 AM
gotcha!
anyway, i m testing it for leaks now and i was wondering if i do the loop correct? see pic below.
and why is there still bubble when i turn off the pump?? is this normal?
Old May 7, 2010, 04:01 PM
Dazmode's Avatar
Air was trapped in pump. That si why you bleed system in teh beginning to get rid of all trapped air in pump a, blocks and radiator.
Old May 7, 2010, 04:06 PM
gingerbee's Avatar
there's not really a wrong order as long as your res feeds your pump your fine. I like to run from rad to hottest block first but that's just me
  #19 (permalink)
Old May 7, 2010, 07:56 PM
Daz... what do you mean? i thought the rad,res and pump were empty before i start pouring liquid in?? so you mean i have to pour liquid in, then bleed them out, then fill it back? now it's not showing the air gap when i turn off the pump though, cz i put more water in the res (3/4 full)
hummm yeah that's what i wanted too.... get the water straight from the rad when the water is the most cooled... i m just afraid that the "heat" from the pump and the "heated" trapped air in the res would make the water less cool... HAHA but i guess that is not how it works?? so you are suggesting rad->block->res->pump? will that work too?
  #20 (permalink)
Old May 7, 2010, 08:01 PM
Dazmode's Avatar
No I didn't mean you need poor water into part. I tried to say that when water start going trough the system you get air pockets here and there and you need to run system for few hours to get rid of air taht needs to be trapped only in your reservoir. Shaking and tilting case helps speed up the proces.
[WTB] blue ray movies ( will be updated with more from time to time) kyle_L Buy/Sell & Trade 3 September 2, 2009 04:20 AM
First time watercooling, setup OK? TALON Water Cooling 3 August 1, 2009 01:46 PM
Is WaterCooling for me? arekieh Water Cooling 10 October 20, 2008 05:50 PM
Watercooling Help EDMCR Water Cooling 24 August 3, 2008 07:24 AM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
