Old April 18, 2010, 11:50 PM
Default need ur suggestion on rad fan
my goal here is to achieve ultra slient water cooling
i have my eye on TFC 480 or 380, seem like quality rad to me
but i am struggling with fan choice
i am thinking between
Noctua NF-S12B FLX
120MM Ultra Quiet Cooling Fan
600-1200RPM
49.2-100.6M3/H
6.2-18.1DBA
or
Scythe Slip Stream Kaze Jyuni
120MM Fan
800RPM
40.1CFM
10.7DBA
anyone have any experice with either ?
and will the low cfm fan have major draw back on the rad i want to use?
i really want to keep everything quite as possible
thanks in advance
Old April 19, 2010, 12:37 AM
stoanee's Avatar
Little more info on the Noctua you are looking at:
Noctua.at - sound-optimised premium components "Designed in Austria"!
heatware
Old April 19, 2010, 06:27 AM
Sushi Warrior's Avatar
Neither. Scythe Gentle Typhoon AP-15 1850RPM. Best fan for rads ATM, with only Noiseblockers being possibly better.
Old April 19, 2010, 06:53 AM
stoanee's Avatar
Interesting, thanks for the suggestion.
heatware
Old April 19, 2010, 07:59 AM
very interesting, i never thought of that, can you point me in the right direction?
i wonder which vendor sell those noiseblocker
Old April 19, 2010, 09:03 AM
AmuseMe's Avatar
Or San Ace fans. But yeah, GT1850 are some if the best rad fans out there.
Old April 19, 2010, 09:19 AM
I think you'd have to order from the states for Noiseblockers.
San Aces are great but they are 38mm fans, and you need a great fan controller to avoid having a jet turbine on your rad.
Old April 19, 2010, 11:24 AM
Dazmode's Avatar
SanAce or Koolance fans would be my choice with fan controller. Low speed fans are all the same IMHO.
Orange Build: Final Video
HTPC Build: Final Video
Old April 19, 2010, 11:36 AM
AmuseMe's Avatar
Daz, dont you have some new 25mm San Aces fans? Or some coming in that push incredible CFMs?
Old April 19, 2010, 11:45 AM
Dazmode's Avatar
Yes, I really like those 25mm versions of San Aces, but I haven't tried them yet. Judging by the weight they should have a solid motor inside.
Best fan for a rad! martin_metal_88 Water Cooling 14 March 24, 2010 06:32 PM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
delta distance : (fan to rad) && (fan to grill) elninio Water Cooling 13 July 12, 2008 03:03 PM
WTB : Rad fan Grille Cptn Vortex Buy/Sell & Trade 4 July 3, 2008 08:25 PM
fan question 2x120mm rad 2 or 4 fans? Somed00d Water Cooling 4 July 30, 2007 11:08 PM
