<~----> need ur suggestion on rad fan - Page 2 - Hardware Canucks
Old April 19, 2010, 02:47 PM
kool, looks like i ll be ordering them from u then daze
120mm by 25mm San Ace fan with fan controller
btw daz, when r u getting more of those Frozen Q liquid fusion reservoir?
Old April 19, 2010, 03:07 PM
Dazmode's Avatar
Yes fresh load of FrozenQ is on the way. Do not forget that San Aces come with bare wires.
Orange Build: Final Video
HTPC Build: Final Video
Old April 19, 2010, 03:28 PM
stoanee's Avatar
Why are San Aces better? Is it simply that they run at a higher RPM=more air? Is it the design of the blades/body? Please enlighten me.
heatware
Old April 19, 2010, 04:02 PM
Dazmode's Avatar
In short words, SanAces has very good static pressure which is great for using on radiators and other tight enviroments (like blowing trough the rack server).
From the Sanyo Denki reference guide:
Sanyo Denki product success relies on:
High projected MTBF (reliability), low vibration, low power consumption, low leakage of flux and high performance.
San aces were first developed in Japan in 1965 and since then they were continued to develop new models with lower noise, lower profile and higher efficiency.
Dc fans expected to perform 40,000 hours at temperature of 60c. Long life family (aluminum frame) has 200,000 hours life.
DC Fans family starts with simple axial fans (we use) to splash proof fans, oil fans, long life fans, blowers, cpu coolers and liquid cooling solution systems (proprietary).
Old April 19, 2010, 05:58 PM
well i got a few yate loon and thermal take fan sitting at home, i can just replace the heads
and yah couldn't wait for the frozen Q reservoir they are uber good looking !!
btw daz did u mod the haf 932 to fit the 120.3 rad? how did u manage to cut metals for case mod?
Old April 19, 2010, 06:10 PM
Dazmode's Avatar
If you put radiator on top, no modification is required; you just loose top 5.25 bay.
In my case (second build) I removed HDD cage completely (you neeed to drill rivets out) and cut extra hole for the fan. It looks good, but draining system is somewhat complicated.
Old April 19, 2010, 08:02 PM
the case i have is thermal take armor + bws6000
the power supply is fixed in the top position
and i really don't like to put rad outside of the case, i think it looks very ugly
so my only option is to put it at the bottom
i ll post pictures later to show the interrior, but what tools u use to cut open the holes for the fan and ventilation?
Old April 19, 2010, 08:25 PM
Dazmode's Avatar
You need to pay visit to Canadian tire.
  #19 (permalink)
Old April 19, 2010, 08:30 PM
the bottom of the case just happen to be 500 mm right on the pci expansion slot edge
i wonder if this length is enough to fit the feser 480 rad, and certainly more ventilation hole and fan holes ll need to be drilled
that is the tricky part =(
  #20 (permalink)
Old April 19, 2010, 08:35 PM
Dazmode's Avatar
i wouldn't bother and just use good dual radiator. And may be single rad at the front, but only if you have heavy overclcock and couple GPU cards in the loop.
Best fan for a rad! martin_metal_88 Water Cooling 14 March 24, 2010 06:32 PM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
delta distance : (fan to rad) && (fan to grill) elninio Water Cooling 13 July 12, 2008 03:03 PM
WTB : Rad fan Grille Cptn Vortex Buy/Sell & Trade 4 July 3, 2008 08:25 PM
fan question 2x120mm rad 2 or 4 fans? Somed00d Water Cooling 4 July 30, 2007 11:08 PM
