  #61 (permalink)
Old April 18, 2010, 03:30 PM
Alright guys, thank you for your help. Here is the steps that I took:
Moved reservoir back to where it was (lower then the pump). Took off the cpu heatsink (shook it for about 20 seconds), installed it back - loaded OS and BOOM!
Full load @ 74C.
But still... WTF?!
heat
rfd
hofo
  #62 (permalink)
Old April 18, 2010, 03:35 PM
MpG's Avatar
MpG MpG is offline
Just to reinterate what some people have already said - pump position (relative to reservoir) doesn't matter once the loop has been primed. Yes, pumps can't pull air, but once a loop is bled (i.e. solid fluid), the loop basically works like a siphon, the pumped fluid effectively pulling more fluid behind it (similar to how a siphon works). Because of this, pumping losses due to gravity in a bled/fluid closed loop are net-sum-zero, with the rises canceling out the drops.
I would like to repeat, especially now that I've seen your board - some Gigabyte boards are definitely known for component interference with some waterblocks, so it wouldn't be the first time. And I notice that your reservoir is directly attached to the waterblock, and that moving it up would alter the mounting pressure on the CPU block. It wouldn't matter much with a proper mount, but you were suffering from poor mounting pressure, it would definitely make a difference.
  #63 (permalink)
Old April 18, 2010, 03:38 PM
My motherboard is Biostar Tpower i55 :)
heat
rfd
hofo
  #64 (permalink)
Old April 18, 2010, 03:43 PM
MpG's Avatar
MpG MpG is offline
My bad, saw the colour-scheme and assumed. Although I'm still placing some faith in my reservoir-CPU block connection theory, which is something I've had happen to me before.
  #65 (permalink)
Old April 18, 2010, 03:58 PM
Very possible, but so far so good :)
heat
rfd
hofo
  #66 (permalink)
Old April 18, 2010, 04:15 PM
KaptCrunch's Avatar
Default Burp that baby
i see your problem is not enough fluid in loop an air pockets
remount this time turn so you read HK upside down
ok un-mount rez so you can lay your system on its MB backside down
place towels to catch spillage while you fill rez with only pump running on #1 setting
IMHO have the rez above rad.....if fart in a pool what way bubbles travel
  #67 (permalink)
Old April 18, 2010, 04:39 PM
thank you.
heat
rfd
hofo
  #68 (permalink)
Old April 18, 2010, 04:52 PM
KaptCrunch's Avatar
oh forgot to ask about your barbs.......the distance from the 0-ring inwards to block .....how far in the hole does it go......it shouldnt go past block threads
  #69 (permalink)
Old April 18, 2010, 05:16 PM
It does not.
heat
rfd
hofo
  #70 (permalink)
Old April 20, 2010, 09:31 AM
74C is starting to become acceptable... I'd return the overclock back to stock, then test full load temperatures. If they're in the 40s then I think you've solved your problem.
HeatKiller 3.0 Mounting? AmuseMe Water Cooling 12 October 11, 2010 09:21 PM
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 04:21 AM
Where to BUY HeatKiller Products??? Chromey Water Cooling 11 January 25, 2010 10:27 PM
Heatkiller D5 Pump Top Technokat Water Cooling 7 January 18, 2010 07:07 PM
Heatkiller + Backplate JD Water Cooling 5 January 3, 2010 08:12 PM
