  #51 (permalink)
Old April 18, 2010, 11:57 AM
So how do I get rid of it?
heat
rfd
hofo
  #52 (permalink)
Old April 18, 2010, 12:00 PM
shaw
Guest
Posts: n/a
Open the block, confirm nothing is blocking the path.
Re-install twice, confirming the TIM spread. Double-check no caps are preventing a good contact on the chip.
No kinks in tubing.
Fill, then bleed system of air by rocking your case sideways, being careful about the rad specifically. This is where most of the air gets trapped.
Make sure the pump is always fed with liquid.
  #53 (permalink)
Old April 18, 2010, 12:31 PM
This has to be a pretty damned big air bubble inside the block, haha. I say give your system a good shakedown, it might be easier to dislodge the bubbles this way if you don't want to take your block apart.
  #54 (permalink)
Old April 18, 2010, 12:35 PM
I would do like others say, open the block to see any gunk or dirt. Second I would take down the whole loop and re-do it. I would mount the res up top near the rad, the second psu option in the case. That way, you're pump is still below.
But the block does seem at fault here, either it had dirt inside and is blocking flow or it's not mounted properly/tightly.
  #55 (permalink)
Old April 18, 2010, 01:03 PM
Deeival's Avatar
Does anyone else have an i7-860? Mine idles at 40 and gets up to 85-90 as well. It's been folding 24/7 for 2 months now without any issues.
Those chips just run hot...
  #56 (permalink)
Old April 18, 2010, 01:09 PM
SugarJ's Avatar
My guess is a huge airbubble in the rad. Try tipping the case on it's side with the pump running.
And FYI, my i7 920 D0 with HK, 655 pump, and feser 360 rad runs at 63-68 degrees loaded at 4.1Ghz and 1.3V, HT on.
  #57 (permalink)
Old April 18, 2010, 01:23 PM
H2O H2O is offline
When the water go out the rad, it get inside the cpu block in the middle, and since the outlet is at the bottom of the cpu block, the block is only partially fill. They are no presure from the pump after the block, only a drop to the reservoit , so of course it will never fill ( the Op should at least reverse the block to make it outlet on top )
In a setup, where the rad is on top , the outlet of the rad should go directly in the reservoir .
  #58 (permalink)
Old April 18, 2010, 01:24 PM
860s don't run that warm.
At (stock) it idles around a very inaccurate 20C and loads at around 43C.
Even with nearly 1.4V running through it, LinX pushes the CPU to ~ 80C full load. Nothing to be worried about.
  #59 (permalink)
Old April 18, 2010, 02:16 PM
Technokat's Avatar
air rises, turn your system about and try and make sure the rad and the cpu block are not the highest points in your system and the air will move out
  #60 (permalink)
Old April 18, 2010, 03:08 PM
If the led display on your motherboard is showing the cpu temps, its only 28C. Maybe there is a problem with the programs you are using to read the temps.
Main- i7 920 C0 @ 4.0, EVGA X58 SLI FTW Mobo, 6GB Corsair XMS3@2000mhz, EVGA GTX470 in SLI, Corsair AX1200, Corsair Obsidian 800D, 2 OCZ 60GB Vertex in Raid 0, 4 WD 1TB Blacks, Logitech G19 keyboard, Logitech G9 mouse, Samsung SyncMaster 245BW.
WC Loop- TFC 360 Rad, HK 3.0 CPU block, EK -EVGA X58 full coverage motherboard and mosfet blocks, MCP655 pump with EK top, Scythe S-flex push/pull.
HeatKiller 3.0 Mounting? AmuseMe Water Cooling 12 October 11, 2010 09:21 PM
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 03:21 AM
Where to BUY HeatKiller Products??? Chromey Water Cooling 11 January 25, 2010 09:27 PM
Heatkiller D5 Pump Top Technokat Water Cooling 7 January 18, 2010 06:07 PM
Heatkiller + Backplate JD Water Cooling 5 January 3, 2010 07:12 PM
