  #41 (permalink)
Old April 18, 2010, 11:21 AM
Alright I am leaving OCCT running for 2 hours. Will get back when I come back tonight.
heat
rfd
hofo
  #42 (permalink)
Old April 18, 2010, 11:22 AM
Dazmode's Avatar
Are you certain that coolant is flowing?
Orange Build: Final Video
HTPC Build: Final Video
  #43 (permalink)
Old April 18, 2010, 11:24 AM
Positive. I even see the coolant move in the reservoir, I feel the tubes and I feel it flowing.
heat
rfd
hofo
  #44 (permalink)
Old April 18, 2010, 11:31 AM
Dazmode's Avatar
I supposed to swirl pretty good inside reservoir at speed 5, not just flow. But if flow is good then it has to be either mount with bad thermal contact or perhaps some crap got inside the block?
  #45 (permalink)
Old April 18, 2010, 11:32 AM
chrisk's Avatar
Folding Captain
Maybe an issue with temp sensor or monitoring program?
What are you using to monitor temps? Try a couple of different programs. Also, how low does your temps fall while idle for a bit?
Fold for team #54196
  #46 (permalink)
Old April 18, 2010, 11:37 AM
Dazmode's Avatar
He said block is warm. That is not good.
  #47 (permalink)
Old April 18, 2010, 11:42 AM
H2O H2O is offline
exactly and the block should not be warm, the water is going down from the block too, I will not be surprise the block have pocket of air inside, this setup is upside down, it should be
res-pump-bloc-rad-res
  #48 (permalink)
Old April 18, 2010, 11:43 AM
The swirl is pretty good in reservoir.
To monitor I use coretemp 0.99.5, OCCT and HWMonitor.
To test cpu - LinX 0.64, OCCT and Prime95 64bit.
Idle temps are 41C
heat
rfd
hofo
  #49 (permalink)
Old April 18, 2010, 11:54 AM
I am pissed...
heat
rfd
hofo
  #50 (permalink)
Old April 18, 2010, 11:56 AM
Technokat's Avatar
ya i was thinking too that he may have a air bubble in the cpu block
HeatKiller 3.0 Mounting? AmuseMe Water Cooling 12 October 11, 2010 09:21 PM
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 04:21 AM
Where to BUY HeatKiller Products??? Chromey Water Cooling 11 January 25, 2010 10:27 PM
Heatkiller D5 Pump Top Technokat Water Cooling 7 January 18, 2010 07:07 PM
Heatkiller + Backplate JD Water Cooling 5 January 3, 2010 08:12 PM
