  #21 (permalink)
Old April 18, 2010, 10:17 AM
Originally Posted by lowfat View Post
Not exactly true. The is only true for priming the pump. If the loop has been bled and primed properly the pump does not need to be lower than the reservoir.
I agree, once the loop has been bled, there is no problem with the pump starving for coolant.
Intel i7 5960x @ 4.5Mhz | MSI X99S Gaming 9 ACK
32Gb G.Skill Trident RGB @3000Mhz | Asus STX audio
Gigabyte RX Vega 64 | Samsung CF791 Ultrawide 1440p (main) Yamakasi Q270 Catleap 2b @1440p (secondary)
Samsung 950 Pro m.2 @ Gen3 x4 32Gbps | Seagate 4Tb with 256 SSD cache | Corsair Obsidian 800D | Seasonic X-1250
HeatKiller 3.0 | EK RX Vega WB | TFC Exchanger Quad Rad |Thermochill PA120.3 rad|TFC Dual rad | Scythe Gentle Typhoon (x9) |Swiftech MCP655 (x2) | Koolance bay Resevior
  #22 (permalink)
shaw
Guest
Posts: n/a
Then in his case I'm correct, since the reservoir is already attached to the case. If he starts his rig, then the pump is not primed.
  #23 (permalink)
Old April 18, 2010, 10:20 AM
AmuseMe's Avatar
Apply more pressure to the block, my guess is that it isnt tight enough to the CPU to transfer the heat.
  #24 (permalink)
Old April 18, 2010, 10:28 AM
If it was starving or not primed, you would hear it struggle with all the air bubbles trapped in it. Its noisy as hell.
And if the pump relies on gravity, why would you be able to mount a radiator above it as well through its outlet? If it has enough power to distribute coolant to the rad above it, it has enough power to take coolant from the res.
  #25 (permalink)
Old April 18, 2010, 10:34 AM
shaw
Guest
Posts: n/a
Because it is fed with liquid from the res, and it can push that liquid towards the higher rad. But unless primed with a higher res, it cannot suck.
  #26 (permalink)
Old April 18, 2010, 10:39 AM
Alright guys, I see the coolant move inside of the reservoir - that means the pump is pumping.
Reapplied the water block (now according to the manufacturer @ 18.7mm) and the thermal paste - so far max is still 87C.
heat
rfd
hofo
  #27 (permalink)
Old April 18, 2010, 10:42 AM
After 3 weeks of usage, I think the priming part and gravity is a moot point at this time. The pump would have died by now if not, Anabioz would posting a thread on why his pump is noisy instead of temps.
  #28 (permalink)
93C... Going to move reservoir higher then the pump I guess. I believe it won't make the difference. But if you guys tell me to. I will.
heat
rfd
hofo
  #29 (permalink)
Old April 18, 2010, 10:43 AM
Try tilting your entire case forward and holding it there for a few minutes, then monitor your temperatures.
  #30 (permalink)
Old April 18, 2010, 10:45 AM
Jackquelegs's Avatar
is the block/radiator warm at all?
Iapetos
Zephyranthes
HeatKiller 3.0 Mounting? AmuseMe Water Cooling 12 October 11, 2010 09:21 PM
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 04:21 AM
Where to BUY HeatKiller Products??? Chromey Water Cooling 11 January 25, 2010 10:27 PM
Heatkiller D5 Pump Top Technokat Water Cooling 7 January 18, 2010 07:07 PM
Heatkiller + Backplate JD Water Cooling 5 January 3, 2010 08:12 PM
