Old April 18, 2010, 10:03 AM
thermal paste is an even spread across the whole cpu ( i do it manually with the plastic card then install the heatsink on it).
heat
rfd
hofo
Old April 18, 2010, 10:06 AM
heat
rfd
hofo
Old April 18, 2010, 10:10 AM
Jackquelegs's Avatar
Your pump is higher than your res
Here's a simple test. Feel the HK block, if it's warm, it's doing its job. If it's not, you gotta worry about mounting
Iapetos
Zephyranthes
Old April 18, 2010, 10:12 AM
shaw
Guest
Posts: n/a
That pump is starving. Probably next to no flow.
All pumps are gravity-fed. It MUST be below the reservoir.
lowfat's Avatar
First thing you should do is remount the block. And just add a block of thermal paste. Most people say it is a superior way to apply than manually spreading it around.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old April 18, 2010, 10:13 AM
Not a big issue ;) Pump is strong enough to handle it :)
heat
rfd
hofo
Okay, I'll be back in a few then. Let me remount the block really quick.
heat
rfd
hofo
Drop the pump below the reservoir, or push the reservoir higher than the pump. You're starving that sucker.
  #19 (permalink)
Old April 18, 2010, 10:14 AM
lowfat's Avatar
Not exactly true. The is only true for priming the pump. If the loop has been bled and primed properly the pump does not need to be lower than the reservoir.
Queen of Dreams WIP
Big Lian Li
Complete
  #20 (permalink)
Old April 18, 2010, 10:16 AM
shaw
Guest
Posts: n/a
No, it is not. As I mentioned those pumps are gravity-fed. Listen to us.
Take your time, why rush. Those blocks, though very efficient are tricky to install.
HeatKiller 3.0 Mounting? AmuseMe Water Cooling 12 October 11, 2010 09:21 PM
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 04:21 AM
Where to BUY HeatKiller Products??? Chromey Water Cooling 11 January 25, 2010 10:27 PM
Heatkiller D5 Pump Top Technokat Water Cooling 7 January 18, 2010 07:07 PM
Heatkiller + Backplate JD Water Cooling 5 January 3, 2010 08:12 PM
