Old April 13, 2010, 11:29 PM
Default monsta.
hey i was just wondering if anyone new the watt ratting on the fesser monsta rad and if it would be substancial for a single loop system running cpu / mobo / and two gpu blocks?
Old April 14, 2010, 06:54 AM
AmuseMe's Avatar
What CPU and GPU's are you cooling?
DEAD CA$H
Old April 14, 2010, 07:32 AM
i7 920 d0 /w HK 3.0
evga x58 classidied EK full coverage block
2x gtx 480 or possibly 2x 5870 toxic 2gb
Old April 14, 2010, 09:21 AM
AmuseMe's Avatar
For the price of a Monsta, you could get two different radiators that would cool better than a Monsta. Personally, I wouldn't put that much on even a Monsta rad.
DEAD CA$H
Old April 14, 2010, 11:17 AM
Keltron 3030's Avatar
i7 920 d0 /w HK 3.0
Just to let you know, the toxic series of cards can't be WC'ed. Their a non-reference design, so no waterblocks will fit it, as they are meant for reference cards.
And the monsta rad is not really worth your time right now. Their bog, heavy, and way too expensive for my liking.
Old April 14, 2010, 12:39 PM
AmuseMe's Avatar
I had no idea that the TOXIC line had a diferent reference design I completely agree with what you say about the Monsta though.
DEAD CA$H
Old April 14, 2010, 01:44 PM
Unfortunately they are not reference. Found a review where they state it's a "in house designed and built pcb"
Linky: Sapphire Radeon HD 5870 Toxic 2GB Review - Overclockers Club
Old April 14, 2010, 03:21 PM
Dazmode's Avatar
It is more then enough if you can get the radiator. It was limited series and won't be produced again. You need good fans to blow it trough efficiently:)
Orange Build: Final Video
HTPC Build: Final Video
Old April 14, 2010, 08:44 PM
thx daz, how bout this one then. wich has more cooling potential the monsta or the 480 xchanger?
Old April 14, 2010, 09:17 PM
Dazmode's Avatar
I believe thick quad is more the ultra thick triple.
