Originally Posted by chriskwarren Watercooling was new to me just a few months ago, and I was pretty nervous about it at first. I now have two rigs watercooled, and I will never go back to air.
I would go with a custom setup though. Will be easy to add to it later on if you do it right, and there are plenty of folks who can help you pick the right parts. My rigs run 100%, 24/7, and watercooling has been a godsend for my rigs. |
it helps when someone shows you the ropes. hum um kruzn I think? he he
but yes once you go water you never go back.
@^ not if you buy it here he he. but your right i have spent thousands on water cooling
all used common prices
swifttech 220. 30$-40$
350/5. 0r 650/5 pump for around 50$-70$
block. 30$-60$.
total not really that bad when you think how much that will cool.
