Well for a GPU only, I would not get an MCP355 or the 655. An MCP350 with an XSPC Res top works - that is a pump, and res. For the radiaotor I would get something not made by swiftech, but if you are under budget, it will be fine. Personally, I would maybe get a duel-pass rad - Hardware Labs SR1 series, Feser, Primochill. Not sure if a 120.2 is really needed, but its better to be safe than sorry. Get the Gental Typhoon fans for the rad, as they are high static pressure at a low noise. for tubing, I personally use 1/2 barbs, and 3/8 x 5/8 tubing. For coolant, distilled water from the drug store and some silver kill coils (or just bitpower TRUE silver barbs).
__________________ DEAD CA$H |
