Old April 7, 2010, 03:19 PM
scruff's Avatar
Default First WC Try finally running
I have a few more things to clean up , sleeving /pump mounts etc. but it's running , What do ya all think ?
Old April 7, 2010, 03:24 PM
gingerbee's Avatar
I think is awesome. for a first what come after this he he. nice build custom paint on the 800D?
Old June 9, 2010, 12:05 AM
dustin1706's Avatar
I have looked at a TON of obsidian dual loop builds in preparation for mine. This is the first one I've seen with the EK dualtop mounted as I plan to mount it. I don't intend to cut out the lower divider, but I like how you drilled the bottoms of the pumps through the divider in your other thread. What made you change it? It still looks cool, just curious.
Also, do you find that you have enough GPU cooling on that single 140?
Are you happy with it? It looks good. I like your choice of colors as well.
Is it reasonably quiet?
Are the lines running down into the lower HD cage just drain lines? Great idea!
I plan on using a 700d with custom window. I already ordered the 150ml reservoirs, but now I think I may need some taller ones.
Old June 9, 2010, 08:29 AM
scruff's Avatar
Thanks , Yes there is enough cooling on the 2- 275 gtx water loop , after 2 to 3 hours of BFBC 2 my temps haven't gone over 62 C . I cut out the divider to get more air into the main area of the case , I also cut out the bottom of the case under the 3.5 HHD cage to get more air in .Currently I am sleeving everything and wiring a Koolance TMS 200 and addon card to monitor air into rads and out of rads as well as water temps in 4 places maybe 6 places. I find this setup is quieter than my Antec 1200 case even though I have 9 fans and 2 pumps in the 800D , yes the bottom lines are drains with valves as well and you can see the fill valves on the top of the case. My res's are 150's and work just fine , Next time I will just buy the tubes and tops.
My buddy is also building pretty much the same rig and we both agreed the lower divider pan had to go because other than the rear grills there was no place to get air to the rads with it in place with this setup. ( took about 10 min to cut it out with a Dremmel) Good Luck with yours I am very happy wit this set up , please post pics so we can see how it turns out
Old June 9, 2010, 08:33 AM
sswilson's Avatar
Love the fit for the 120 rad on the rear... did you have to cut out holes for the tubing or did it fit right in like that?
Old June 9, 2010, 08:42 AM
scruff's Avatar
The rear rad is a Black Ice exteme 140mm , I traced ot the 140mm fan housing and cut out the facory grill to get as much air though the rad as possible , I then drilled new holes for the fittings with a step bit and used the rubber gromets from the lower divider pan to seal and protect the fittings
Old June 9, 2010, 09:53 AM
C130AVN's Avatar
Nice! I'm impressed with your attention to detail.
Old June 9, 2010, 10:37 AM
Dazmode's Avatar
Nice solution for single rad! Great case for WC, I just working on my own version.
Orange Build: Final Video
HTPC Build: Final Video
Old June 9, 2010, 10:57 AM
scruff's Avatar
Hey Daz . I'm out of the hospital again so just waiting for more stuff from Nils and get my sleeving done. Kerry is finally getting started on his ,I am also looking at another case to play with (so many to choose from) Thanks again for all your help
Old June 10, 2010, 12:24 AM
aviduser's Avatar
Nicely done, you sure dove right in head first
Puts my first loop to shame for sure. Sorry to hear you've been in the hospital, I've been ill for the last 3 months. Anyway keep up the good work!
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
RAM not running at right speed Vegas RAM 16 May 31, 2010 02:02 PM
Back up and running nckid4u HardwareCanucks F@H Team 0 June 6, 2009 11:26 AM
OCCT Running at 65%... Realityshift Overclocking, Tweaking and Benchmarking 7 April 22, 2009 01:36 PM
My guide to a smooth running PC Toronto122 O/S's, Drivers & General Software 27 April 14, 2009 03:00 PM
Running RAM 1:1 still the best? biff RAM 12 January 29, 2008 07:30 AM
