Old April 6, 2010, 08:28 PM
Default Using prestone as additive?
I forgot to buy HydrX in my recent order for my new watercooling setup. Problem is, I have the time this week to do the build so was wondering if prestone used in diesel engine could do the trick?
Old April 6, 2010, 08:35 PM
Soultribunal's Avatar
I'm pretty sure you could but I would not reccomend it.
They although sound similar do have some differences in composition. Espically the newest formulations in order to keep in compliance with stricter Coolant standards.
ST
Old April 6, 2010, 09:07 PM
as a test,sure. longterm it might eat up tubing, maybe
Old April 7, 2010, 04:55 AM
it may work but may not be as effichent !!
Old April 7, 2010, 05:26 AM
gingerbee's Avatar
it works fine i am just not sure of the mix you'll have to do your own research it has been a long time since i did this.
Old April 7, 2010, 06:31 AM
Distill water is always the best option. :D
Old April 7, 2010, 06:43 AM
I would suggest premixed antifreeze. It'a available almost anywhere and you won't have to worry about water to coolant ratio. You might even consider diluting it a little.
Old April 7, 2010, 08:44 AM
astrodanco's Avatar
So far as I know, you only need to add antifreeze to your coolant if you have mixed metals or sub-zero coolant temperature in your loop. Otherwise it's not a good idea and will hurt your cooling performance.
Core i7 920 (D0) @ 4.0Ghz, P6T Deluxe V2 (0901), 12GB Corsair CM3X2G1600C7 @ 1600 7.7.7.20 2T, ATCS 840, Antec TPQ 850, Radeon 4850, TMS-200 + TMS-EB200, EK Supreme HF, EK-D5 dual top, 2x MCP-655-B, MCR-320, 6X Skythe D1225C12B5AP-15, Durelene tubing. Obviously not a gamer as you can tell by the low end video card.
Old April 7, 2010, 11:06 AM
gingerbee's Avatar
it will not cool as good as water? true but with out ethylene glycol is will grow things. you can just use iodine or silver too ah. not a good idea it's in almost all cooling you mix it with distilled water in computers.
Old April 7, 2010, 12:33 PM
MpG's Avatar
MpG MpG is offline
Glycol-based substances have worse thermal characteristics than water, so they won't help your cooling any, and they keep changing formulations these days, so while there probably won't be any problems, it's not a 100% thing, especially where the seals are concerned. Your best bet is to use Distilled and find a copper-based biocide (at an aquarium store, perhaps), as I've seen long-term complications where iodine-based biocides mix with copper.
What additive are you using in your water MarkOne Water Cooling 45 March 8, 2010 03:12 PM
Bike won't start after using NOS fuel additive CTA Off Topic 17 May 24, 2009 02:42 PM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 04:34 PM
