Old April 7, 2010, 01:56 PM
KaptCrunch's Avatar
hydryx is EG the diesel is PG both are alcoho based, if in a freezing temp range are you ? if so mix to ambiant low (freezepoint) to protect. (note pre-mix is 50/50 with around -37c freeze point)
other just mix for 7% with distilled water for mixed metals loop, if loop all same just use distilled water with silver coil
Old April 7, 2010, 02:20 PM
The water would not be chilled (ambiant cooling only) But what is silver coil??
Old April 7, 2010, 02:39 PM
gingerbee's Avatar
this is one
Old April 7, 2010, 05:22 PM
scruff's Avatar
You would also have to worry about higher viscosity using automotive Glycol (pump will have to work harder)
What additive are you using in your water MarkOne Water Cooling 45 March 8, 2010 04:12 PM
Bike won't start after using NOS fuel additive CTA Off Topic 17 May 24, 2009 02:42 PM
Help With Coolant Additive Johnnyl168 Water Cooling 18 November 29, 2008 05:34 PM
