Old April 3, 2010, 07:26 PM
Realityshift's Avatar
Default EVGA GTX 295 co-op hydro copper
Hey guys, shot in the dark, but anyone know the exact screw specs of the screws used to hold the waterblock to the card? Previous owner lost the screws and well I need to buy new ones... Aside from going to a specialty fastener shop I was gonna see if anyone knows the specs to make it a little easier.
The Builders Hammer
Old April 4, 2010, 07:53 AM
Liu Kang's Avatar
Did you get the manual with the block? All of my HK blocks had the screws listed in the manual If they aren't listed there, I'd call the manufacturer directly.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old April 4, 2010, 01:07 PM
Called EVGA already, apparently they dont have the specs... nor can they send me new ones >.< EVGA win on this mater..
The Builders Hammer
Old April 4, 2010, 01:48 PM
hmm..no idea. but can you pick up a few from your local store? approximate lenght. see wich one does it and then buy more of that one :)
Old April 4, 2010, 07:12 PM
jtf2's Avatar
i would bet m3 or m2.5 is the size you need
Old April 4, 2010, 07:40 PM
kruzn4evr's Avatar
If you take the card to an RC Hobby shop they should be able to tell what size and should hopefully have them, RC cars use alot of similar type screws.
I'm rather surprised that EVGA isn't more helpful, I needed screws for a dual PCB 295 and although it took some doing I did get them to send me the screws.
Old April 4, 2010, 08:05 PM
Im going to give EVGA a call during normal weekday hours and see if I can talk to an RMA tech not just a tech support guy, I see no reason why they wouldnt atleast have specs on these screws, they are rather small though, a decent amount smaller then any waterblock or pc screws I have laying around.
The Builders Hammer
Old April 4, 2010, 08:31 PM
kruzn4evr's Avatar
I would definately try to talk to someone in RMA, as I said, it took some doing (bugging!) but they did send me a set for the 295. Also, RC hobby shop is your next best shot at finding the proper size, I was really shocked at the similarities in parts for RC cars and computer screws, this shop near me has everything including all the tiny plastic washers and such.
470/480 With water blocks " EVGA hydro copper FTW " ZZLEE Video Cards 8 March 28, 2010 11:27 AM
Huge EVGA Fail!!!! GTX 295 Hydro "copper" mixes ALU and CU in the same BLOCK! zlojack Video Cards 13 March 24, 2009 06:26 PM
EVGA Geforce GTX285 Hydro Copper CasheKicker Water Cooling 4 February 28, 2009 12:43 PM
EVGA GTX 295's at NCIX soon? kruzn4evr Video Cards 31 January 8, 2009 06:20 PM
EVGA Launches e-GeForce 9800 GX2 Hydro Copper 18 1024MB Hardware Canucks Press Releases & Tech News 0 June 1, 2008 09:12 AM
