Old April 3, 2010, 05:25 PM
Default Cloudy tubing
I have primochill lrt clear 1/2 inch tube and i love it.. but after cleaning and flushing my loop with distilled the purple uv feser coolant i used is still on the inside of the tubes and it bothers me. I dont think it will have an effect on performance but I wanted to know what you guys thought .. can i use the tubes again or will it start to come off in my loop if I do..
I already ordered new 1/2 feser clear tube from dazmode :P yay i heard about you from here daz :D great shop you have...
I just wonder if the crap will come off if i use the tubes in another loop i was going to do..
thanks for your time and let me know
Old April 3, 2010, 05:32 PM
I'm thinking the dye from the coolant probably just seeped into the plastic. I doubt it will cause any problems.
Old April 3, 2010, 08:45 PM
ottoyu34's Avatar
If it's a cloudy white-ish colour on the inside. That's is the stain caused by the fluid.
ATCS 840| Core i7 920 - 4.2Ghz - H20| Corsair Dominator GT 1600Mhz 6GB| EVGA X58 Classified| GTX480 2-Way SLI| WD 640GB X2 (Raid 0)| Corsair HX1000W
Old April 3, 2010, 09:08 PM
AmuseMe's Avatar
Any color fluid will stain any type of tube. It shouldn't effect temps or performance though, but I would keep to the same color you have been using. Colored tubing and distilled+silver ftw.
DEAD CA$H
Old April 4, 2010, 01:21 AM
astrodanco's Avatar
Cloudy white is often just plasticizer that has leached from the tubing.
Core i7 920 (D0) @ 4.0Ghz, P6T Deluxe V2 (0901), 12GB Corsair CM3X2G1600C7 @ 1600 7.7.7.20 2T, ATCS 840, Antec TPQ 850, Radeon 4850, TMS-200 + TMS-EB200, EK Supreme HF, EK-D5 dual top, 2x MCP-655-B, MCR-320, 6X Skythe D1225C12B5AP-15, Durelene tubing. Obviously not a gamer as you can tell by the low end video card.
Old April 4, 2010, 11:12 AM
nah its like a cloudy purple lol. The main reason I am asking is becuase the case i had the tubing and loop in is pretty small and the tube is keeping the shape that it had in the loop so it would be nice to not have to redo the tubes and cut my hands up getting the shapes and sizes I needed again lol
Thanks
tubing Ken_C Water Cooling 3 January 10, 2010 10:26 AM
[WTB] 1/4"id tubing kyle_L Buy/Sell & Trade 1 October 19, 2009 04:50 AM
[WTB] 7/16 ID 5/8 OD Tubing enaberif Buy/Sell & Trade 5 September 27, 2009 07:32 AM
Smallest ID of tubing enaberif Water Cooling 5 September 26, 2009 04:43 PM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
