Old April 13, 2010, 04:05 AM
Varroa's Avatar
Got my eco today and put it in. Using the stock fan and letting the bios manage the fan speed it seems to do a decent job. At stock CPU speeds my temps are about equal or slightly less than my Ven II (which was using a noctua fan). Under full load (Prime95) temps were a couple degrees lower as well. The fan speed was about 800 RPMs when idle and was no louder than a noctua but when under load the fan speed went up to 1500 rpms and was audible over my other fans.
I'll try and give a bit bigger review in a bit, stay tuned!
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old April 13, 2010, 06:06 AM
ipaine's Avatar
Well, I know I like my H50. I have it set to run at 30% speed until it hits 34 then it goes to 90%.
This gives me about 29 on idle and then about 36 on load. All of that is with my Q6600 OC'd to 3.6GHz
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old May 6, 2010, 10:39 AM
I have the H50 as well, in the default config with one fan it keeps my i7 OC'd to 3.6 around 32-36 on idle and around 50-55 when taxed. I had trouble deciding which one to get at first and I couldn't find a review comparing them (strangely). I went with the H50 because its been around the longest and had overall positive reviews.
Old May 7, 2010, 10:58 AM
MonsterSound's Avatar
Default Head to Head review of the CoolIT ECO and the Corsair H50
A Head to Head review of the CoolIT ECO and the Corsair H50.
Nice job by HardwareHeaven.com
Fairly evenly matched but the H50 beats the ECO slightly when cooling at 4ghz OC as well as being a bit quieter.
(Glad I got the H50 after all - still $62 at BD btw)
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old May 14, 2010, 05:14 PM
RBA RBA is offline
Has anyone had any problems with their H50 system? Specifically some weird noises from the pump unit?
Old May 14, 2010, 07:12 PM
The pump on the H50 is louder than the fan according to silentpcreview and a few guys on their forums.
Old May 14, 2010, 07:32 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Is it a gurgling or whooshing sound? I find in a lot of these pre-built, pre-filled units that after a little bit of time some air works its way free and ends up in the pump. THAT increases the noise output of the unit by a good bit....and unlike a custom loop you cant burp it to get it out either.
Old May 14, 2010, 07:57 PM
Guuulurp! Not looking forward to that. The H50 is nice and quiet right now, but, time will tell.
Code:
- Mahatma Gandhi
  #19 (permalink)
Old May 14, 2010, 08:00 PM
AkG's Avatar
AkG AkG is offline
Don't get me wrong it doesn't happen to ALL of them....BUT sometimes the filling stage gets rushed and /or QA dept isn't totally on the ball (in other words its a classic "Friday" or "Monday" build) and not all the air pockets gets flushed out before it gets sealed. Thats the downside to a sealed unit....what you get is what you get. ;)
  #20 (permalink)
Old May 14, 2010, 08:13 PM
headsh0t's Avatar
Can you RMA for that if that does end up happening to the unit? What is the warranty like on the H50 anyways??? ...
CoolIT Reveals New ECO, Vantage, OMNI and Maestro Products SKYMTL Press Releases & Tech News 9 March 6, 2010 06:49 PM
Coolit Systems Domino ALC LEAKING OH NOES! Pelt Water Cooling 18 August 30, 2009 07:38 AM
CoolIT Systems Unveils HD 4870 X2 Liquid Cooling System MAC Press Releases & Tech News 0 August 18, 2008 01:46 PM
CoolIT Systems Freezone Elite Scratch Member Reviews 25 June 18, 2008 03:43 PM
