Old November 2, 2007, 04:31 PM
Originally Posted by Song View Post
Hey guys, the Scythe Ninja, is it much good with the stock cooler?
Ninja > Stock Cooler
Old November 2, 2007, 04:32 PM
ahaha, sorry I said that wrong, I meant with its stock fan. Is the Scythe Ninja worth it to use just with its stock fan.
Old November 2, 2007, 04:35 PM
Stock ninja fan works great. The ninja is good enough to the point you can usually run it without a fan just for normal usage :)
Old November 2, 2007, 04:40 PM
Hmmmm.... I've read some reviews on the Ninja and especially in this one AnandTech: Cooler Master GeminII: Performer or Poser?
it points out that the stock fan doesn't nearly wow you like the hype does. Is it most likely that the review for the stock fan of the ninja poorly done? or is that really... the correct temps of the Ninja.
Scythe Ninja Rev.B CPU Cooler is another one.
Old November 2, 2007, 04:48 PM
I currently have a ninja fan in my case which is more than enough for airflow.
Cptn Vortex's Avatar
The Ninja is an excellent cooler for the price. I used an Antec Tricool fan on it, because it operates at a higher speed, with more airflow, but the stock fan is very silent, and does move a significant amount of air. You will more than likely not have to change it.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old November 3, 2007, 02:40 PM
stoanee's Avatar
I have a Thermalright Ultima 90 sitting at home with two Scythe S-Flex SFF21E 120 mm fans. I will try them in a single and push-pull configuration and let you know how they work on my quad.
heatware
Old November 3, 2007, 03:01 PM
b1lk1's Avatar
If you can get a Noctua cooler cheap enough and put some good fans on it it works very well. I have the NU-9F (92MM version) and with 2 Panaflo's it works very well for my B3 Quad. But I do agree, the Thermalright Ultra-120 is the top dog. The Ninja is best for lower airflow and silence and I don't think anything else in it's class can match it under those conditions.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
  #19 (permalink)
Old November 3, 2007, 03:57 PM
Might as well go for the Ultra 120 if you go for the noctua.
  #20 (permalink)
Old November 3, 2007, 04:19 PM
b1lk1's Avatar
If you read my post then you would have realized that is exactly what I said..........
ds3r SB heatsink Mr. Cipher Air Cooling 22 February 28, 2008 03:39 PM
how much paste on the HSi heatsink magictorch Video Cards 0 February 23, 2008 03:48 PM
Cooling question (fan and heatsink) Mr. Cipher Water Cooling 1 November 6, 2007 09:26 AM
COOLINK introduces the Silentator CPU Heatsink Babrbarossa Press Releases & Tech News 0 June 12, 2007 05:47 AM
Why not sell w/o heatsink? Babrbarossa Video Cards 11 May 1, 2007 02:20 PM
