Hey guys I just had a couple questions about the way I plan on setting up my loop with 2 gtx 480 FTW I intend on buying hear in the near future. any opinions are welcome and appreciated.
Currently in my system now:
-Coolit Boreas Tec chiller
-HK 3.0 cpu block
-koolance x-58 classfied nb and vreg blocks
- swiftech triple rad
-evga classified (59) original release
- tubing size is
1/4 id
Question #1
Now if I get 2 of these gtx 480 FTW will the water blocks on them allow me to use one of these
Bitspower Shining G 1/4 Silver 1in. D-Plug Set for Direct Connect # BP-WTP-C38 direct connect fittings between the cards? I have an x58 classified original release and was just wondering what the spacing would be and if the evga blocks would allow for a direct connection setup between cards. Then I don't require tubing between cards.
So it would go fitting on top side of #1 (top) card for entrance of water, direct connection inside between cards and another barb on the bottom side of the #2 (bottom) card for the exit of water. I dunno if i explained that for u guys to understand lol.
Question#2
The way my loop is now is Tec - pump - cpu - nb - vreg - triple rad - back to tec.
I plan to also get another double rad and use that to help exhaust the heat from the added 480's.
So the new configuration would go like this then Tec - pump - cpu - nb - vreg - triple rad- gpu1 - gpu2 - double rad - return to tec.
Does this seem like the best possible way to setup my loop after acquiring the 480s?
Question #3
I am using pretty damn small tubing (1/4 id) compared to what most people use as my Boreas requires a relatively slow flow in order for the tecs to adequately cool the liquid. Right now everything works fine and I am good with temps. Would all this extra stuff ( 2x gtx480s and double rad) be going past the pumps limits? I figure since the tubing is so small it shouldn't be a problem.
Its probably just gonna end up being trial and error but I thought maybe someone out there would have an idea.
Any thoughts or opinions are greatly appreciated guys. Cheers!
