Old March 28, 2010, 12:38 AM
Yeah.. so what i said.
Old March 28, 2010, 07:11 AM
Levesque's Avatar
You should buy Bitspower True Silver instead of Silver shining. That way, it will also kill the small things that will try to grow in your loop and steal the show. :)
Also, you just need to use DangerDen or Feser (Dazmode.com sell them for 9$) SLI/Crossfire fittings between the 2 cards.
With 2 480 in SLI, you will need 2 loops. I know, since I use 2 loops and 3 triple rads to cool my Tri-Crossfire (5970+5870) + i7 920 set-up.
And be prepared to see your ambient temp raising by 3 or 4 celsius after a couple of hours of gaming/benching. 480 SLI... that's some serious heat/watts to dissipate. Watercooling is not magic. The heat needs to get out somewhere!
Old March 28, 2010, 07:38 AM
scruff's Avatar
Originally Posted by Whoopyour View Post
Yeah sorry about that. I was just talking about the fact that since im using a smaller tubing size I have more pressure to push through more stuff in my loop. If it was a larger tube size there be more volume to push through all the blocks and the pump would struggle more. I think that's how it works inst it?
With a larger loop you will need larger tubing , without going into a 6 page speal you will loose the ability to reject heat from your water blocks the larger your loop gets with small tubing . Volume will always be peffered over pressure , more volume more heat transfer . My 2 cents
Old March 28, 2010, 09:27 AM
thanks guys. From what people are saying i think im gonna have to go with a 2nd loop. 1/2 id tubing, another pump, res, and rad. Man my case is gonna be so full. lol
Old March 28, 2010, 09:41 PM
Realityshift's Avatar
Time for an 800D
The Builders Hammer
Old March 29, 2010, 06:34 PM
scruff's Avatar
Originally Posted by Realityshift View Post
Time for an 800D
Love the case but I am still running out of room for my dual loop wc system
Old March 29, 2010, 09:29 PM
hah shit eh well ive got a haf 932 modded alot and its not a small case either. but what i was thinking
was going with one of these mounted externally on the back:
Swiftech MCR220Drive
Its a rad/res combo and it comes with an mcp355 pump mounted on the bottom so it gets rid of some connections needed and the bulk which is what im looking for but im not sure if its enough for dissipating the heat made from two fermis.
With one of these to mount it:
Swiftech MCB-120 Rev 2 Radbox Radiator/fan housing - Black
and then using some 1/2 id tygon norprene tubing to connect to gpu 1:
Tygon A-60-G Norprene 1/2in. ID 5/8in. OD Industrial Tubing AFL00036
and then connecting gpu #1 and #2 with one of these:
Bitspower Matte Black G 1/4 1in. D-Plug Set for Direct Connect # BP-MBWP-C38
and these as fittings:
Bitspower Matt Black 1/2in. Compression Fittings for 5/8in. OD Tubing # BP-MBCPF-CC4
and of course two of these:
EVGA | Products
Just an idea what do you guys think? thanks
Old March 29, 2010, 09:34 PM
AmuseMe's Avatar
Wait, did I miss something or is that MCR220 cooling everything by itself You'll need more than a Swiftech 120.2 rad for two Fermis.
  #19 (permalink)
Old March 29, 2010, 09:44 PM
NCIX.com - Buy HW Labs Black Ice GTX Xtreme 240 Dual 120MM Water Cooling Radiator Black 1/2IN Barbs - RAD-3420 In Canada.
I hear good things about these but could it be mounted externally like the swiftech?
Then im gonna have to mount pump and res somehwere too.. BAAH i need a mountain Mods case or something lol...
Comment Thread for GTX 480 and GTX 470 Reviews SKYMTL Video Cards 493 May 22, 2010 08:37 PM
gtx 480 benchmarks???? t_mo_t Video Cards 1 March 26, 2010 02:48 PM
NVIDIA Clarifies Official GTX 480 and GTX 470 Launch Date matsta31 Press Releases & Tech News 76 March 9, 2010 02:07 AM
NVIDIA's Next-Gen Parts Get Named: GTX 480 & GTX 470 SKYMTL Press Releases & Tech News 67 March 6, 2010 09:23 PM
First PIC of the GTX 480 MarkOne Rumor Mill 6 March 4, 2010 09:51 AM
