Old March 23, 2010, 08:55 PM
Default What kind of pump for....
I want to put the radiator in the basement (well just under the floor when my computer is) The tubing would go about 3 feets in the back on the computer, then 3 feets down in the basement. So my question is, how much pump power do I need? I just want to watercool the cpu (my I7 rig) ... I already have a mcp600, but I doubt it will be enough..
Opinions please?
Old March 23, 2010, 09:43 PM
lowfat's Avatar
What is the head pressure of the MCP600? It should be enough as long as the loop isn't to restrictive.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 23, 2010, 09:46 PM
SugarJ's Avatar
A MCP655 should be able to do it, they have a maximum head pressure of 10 ft, which means it should be able to pump straight up 10 ft. Keep in mind that you have to include the head pressure in your computer as well, so add another 2 feet from the bottom of the case to the top.
Edit: specs here state the MCP600 has a 10 ft. head pressure as well. It should do it. SWIFTTECH
Old March 23, 2010, 09:49 PM
Head pressure doesn't matter in a closed loop, the force required to push the water up is offset by the force of the water coming back down.
Old March 23, 2010, 10:02 PM
SugarJ's Avatar
OK, how do you get a closed loop without pumping the water through it at least once? My loops have never filled both inlet and outlet sides without pumping, especially with restrictive blocks. Maybe I've been doing something wrong.
Regardless, we all agree that his current pump should do it.
Old March 23, 2010, 10:13 PM
KaptCrunch's Avatar
what you are refering to is load on pump motor
head pressure is the max verticle discharge from pump head
the vertical lift in height (usually measured in feet of water) at which a pump can no longer exert enough pressure to move water.
At this point(height), the pump may be said to have reached its "shut-off" head pressure as the flow rate at that point is zero.
The higher a pump's head pressure, the more powerful the pump.
D5 headpressure is 19ft spec.pdf so from pump outlet and above its 19ft @ sea level
Old March 23, 2010, 10:17 PM
AmuseMe's Avatar
Doesnt an Laing 3.2 (MCP355) with an aftermarket top have more head-pressure than the 655?
Old March 23, 2010, 10:25 PM
KaptCrunch's Avatar
stock ddc is 20ft head ddc.pdf
amuseme its flow not head on aftermarket tops you loose some head
Old March 24, 2010, 06:29 AM
AmuseMe's Avatar
Ah... But who wants to use a stock DDC top So it's double the 655 though.
Old March 24, 2010, 06:41 AM
MarkOne's Avatar
Since you pump will be in the basement , you can look at a 120 volts one, I use a lot of Eheim pump in my house for my aquariums, I use the one rated 10' and my pump is 8' below the top level of my aquarium, I lost flow of course, so I use a higher flow one that I will use it if it was direct at the side of the aquarium.
how about a contest of some kind ruffus Water Cooling 93 December 14, 2009 07:45 PM
What the heck kind of name is Mushkin?? clone63 Off Topic 28 July 6, 2009 12:38 AM
What kind of PPD should I be getting? Daygard HardwareCanucks F@H Team 2 April 29, 2009 07:06 PM
UPS - the good kind Dr_BenD_over Peripherals 8 December 17, 2008 08:05 PM
Distro with some kind of Lightscribe support? sswilson O/S's, Drivers & General Software 8 May 30, 2007 07:09 PM
