<~----> Best fan for a rad! - Hardware Canucks
Old March 23, 2010, 07:18 AM
martin_metal_88's Avatar
Default Best fan for a rad!
Hey guys! So I post here in a different thread then my previous because my question is completly different and pointy. I want silent fan to go on a triple single pass rad. That's good and easy but where it come harder is...I would like some fan that have led and led can be turned off because for now the computer is next to my bed. I know Enermax have appolish but they are not that good on RAD I am pretty sure about that. If there is no opiton then just suggest me good fan! Thx you again and again guy!!!
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old March 23, 2010, 01:53 PM
Yate Loons FTW...
The Zalman F3s are pretty solid fans too, Cptn_Vortex suggested them to me, and I was pretty impressed. Although I bought those Yate Loons, the ones that usually go on sale at NCIX, so darn quiet and moves good amount of air. Those do push a good amount of air, so unless you got a fan controller, or you undervolt them or even if your case is not right near you and is closed, you should be fine.
For silent fans Yate Loon D12SL-12, these are the rating per google 47CFM/1350RPM/28dB.
If you don't mind a little more noise, you can get almost double the air pushed with Yate Loon D12SH-12 - 88CFM/2200RPM/40dB.
Some people also like Sycthe S-Flex fans, and frankly those are really good fans for water cooling too. Noctuas are the kings of silent fans, unfortunately I find them really pricey.
Old March 23, 2010, 02:16 PM
BigDogg's Avatar
It seems like the Scythe Gentle Typhoons are a favourite among most people. I am going to run S-Flex and maybe switch over to the Gentle
Old March 23, 2010, 02:57 PM
AmuseMe's Avatar
Yes, the Gentel Typhoons are a favorite amoung many - but it isnt the best "bang for buck". Another favorite is San Ace/ Delta fans, but they are expensive. Yateloons are definitly the best "bang for buck" but I would not cheap out on fans. The fans are doing the most work cooling your loop. You can have the cheapest swiftech rad with a san ace doing 110+CFM and it would be good.
Look into the Scythe S-Flex "F"s or "G"s. Or the Gental Typhoons.
DEAD CA$H
Old March 23, 2010, 03:32 PM
Thx guys it seems that yate are pretty loved here so I will keep them...I actually have like 20 laying in a closet here so they will come back;)
Ask for more
Martin_metal_88
Old March 23, 2010, 03:36 PM
JD JD is offline
The only concern is the vary quality between so-called Yate Loon fans. If you pull up Vapor's fan reviews over on XS, you'll see some Yates perform pretty bad, where as others perform quite well.
I currently have 3 1450RPM Gentle Typhoons on my HWLabs SR1-360, and they seem to be doing a fine job. Extremely quiet (I'd go as far to say silent from a normal distance).
Old March 23, 2010, 03:42 PM
Well all the fan will be plugged onto a fan controller so i will be abble to keep them silent and find a good lvl between sound/perf. If they are not what I am searching for then...I will buy new fan:P
Ask for more
Martin_metal_88
Old March 24, 2010, 02:10 PM
Yate Loon FTW.. Yate Loon FTW..
Skinnee Labs actually uses Yate Loons for most his radiator review, means he trusts them a lot. You know lots of people forget to clean dust of their rads, which does cause lack of air flow too.
But yeah. Scythe's are my no.2 pick, I'd happily live ever after with them.
Gentle Typhoons FTL.. Gentle Typhoons FTL..
Old March 24, 2010, 02:48 PM
gingerbee's Avatar
well i don't like yate loons they tend to not perform very well. just my experience ( running 800-1350 yate-loons right now and i have had much better i mean there quite and all i ma not too worried about noise so )
Old March 24, 2010, 03:30 PM
Don't worry Miggs I already think about dust in the rad. I will use a aerospatial grade dust filter between the grill and the fan. These filter are know to prevent dust without taking away airflow so I should be good with that;)
Ask for more
Martin_metal_88
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
delta distance : (fan to rad) && (fan to grill) elninio Water Cooling 13 July 12, 2008 03:03 PM
WTB : Rad fan Grille Cptn Vortex Buy/Sell & Trade 4 July 3, 2008 08:25 PM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
fan question 2x120mm rad 2 or 4 fans? Somed00d Water Cooling 4 July 30, 2007 11:08 PM
