Old March 24, 2010, 03:30 PM
Soultribunal's Avatar
CM R4 would get my Vote.
ST
www.realhardwarereviews.com
Old March 24, 2010, 03:34 PM
martin_metal_88's Avatar
ST
I already concider these fan but they have LED that can't be turned off The computer is next to my bed and I am already suffering from insomnia so if I have a big and lighty computer that won't help. More fan builder should do like enermax and put a switch on their product.
Old March 24, 2010, 04:02 PM
Lima's Avatar
Originally Posted by martin_metal_88 View Post
I will use a aerospatial grade dust filter
Where do you get that and, is it affordable?
Old March 24, 2010, 05:30 PM
ottoyu34's Avatar
depends on your budget:
$20: Noiseblocker M12-S2
<$20: Yate Loon
YouTube - Martinm210's Channel
check out his fan test and it should help you out.
Old March 24, 2010, 06:32 PM
well it's expensive because it's aviation grade but it's mainly looking like iron wool. With more space between the fiber. The only problem with that...once it's full of dust you can only trash it. I only try it to because I am searching for the best filter. My next test will be tam tam tam...back door hum...moustiquaire...mosquito net??? The fiber are small hole are not that big and it's cheap. That could be nice.
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
delta distance : (fan to rad) && (fan to grill) elninio Water Cooling 13 July 12, 2008 03:03 PM
WTB : Rad fan Grille Cptn Vortex Buy/Sell & Trade 4 July 3, 2008 08:25 PM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
fan question 2x120mm rad 2 or 4 fans? Somed00d Water Cooling 4 July 30, 2007 11:08 PM
