  #31 (permalink)
Old March 22, 2010, 04:26 PM
martin_metal_88's Avatar
Ok so if I understand good...what I am not doing actually...If I get the 360 and I want to use these tub
Primochill 1/2"
Which barbs or fitting or any I need XD damn I never figured out that the first loop would be that hard:P
  #32 (permalink)
shaw
Guest
Posts: n/a
I'm giving you for free all the barbs and tubing that you need - already installed and torqued (and I can tell you they won't leak) and you don't want them? I can understand that the tubing color (translucent) may not be what you want in your loop, but barbs... oh well. I'll remove them from the components, and keep the tubing for a future built.
  #33 (permalink)
Old March 22, 2010, 04:27 PM
MarkOne's Avatar
2 pump
2 cpu block
2 reservoir
2 rad
the one I link are in pair, so you need 4 set
Edit : Shaw wrote at same time. so it fix your problem
  #34 (permalink)
Old March 22, 2010, 04:30 PM
AmuseMe's Avatar
Originally Posted by MarkOne View Post
wait a minute
the Koolance is G1/4 no need for adaptor , I know I have one...
http://www.hardwarecanucks.com/forum...9-koolance.jpg
PrimoChill Radiator
  #35 (permalink)
Old March 22, 2010, 04:32 PM
MarkOne's Avatar
Originally Posted by AmuseMe View Post
PrimoChill Radiator
ya I know , but i tough you was talking about the Kolance, since I know Shaw was giving him the fitting
  #36 (permalink)
Old March 22, 2010, 04:33 PM
AmuseMe's Avatar
Ah, I didnt see that post. But yea, because of that rad, he will need two G3/8 barbs/ adapers.
  #37 (permalink)
Old March 22, 2010, 04:36 PM
MarkOne's Avatar
you don't see it because thing happen at the back. I bough the CPU , the board and the ram from Shaw, and Martin the rest less the CPU block ,
  #38 (permalink)
Old March 22, 2010, 05:47 PM
I was all away with the dimension 1/2 1/4 these are to much for my head Ok so if I go with the 360 all the tub and tubbing you are giving will fit. it's hard to go back to school and keep the brain on after a spring break Sorry guys for my ignorence
  #39 (permalink)
Old March 22, 2010, 06:53 PM
shaw
Guest
Posts: n/a
No problem. Remember, I'm selling you a complete loop minus the CPU block, and the liquid. Barbs, tubing, everything is compatible, and the loop is fully functionnal.
  #40 (permalink)
Old March 22, 2010, 06:56 PM
MarkOne's Avatar
Martin 1/2 is the diameter of the tube, the 1/4 is the tread of the fitting , ( the part you screw ) they mainly all 1/4 except some rad and other stuf.
Optimal water setup Fudd Rucker Water Cooling 8 October 15, 2009 10:26 AM
Custom Water Cooling Setup BALISTX Water Cooling 37 July 29, 2008 10:02 PM
Need help with first water cooling setup. BALISTX Water Cooling 18 March 23, 2008 10:11 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 07:22 PM
Anyone looking for help with a water cooling setup, please post here Misoprostol Water Cooling 75 September 17, 2007 11:09 AM
