  #21 (permalink)
Old March 21, 2010, 06:07 PM
MarkOne's Avatar
nothing I read here will stop me to buy a Swiftech XT .....
  #22 (permalink)
Old March 21, 2010, 06:12 PM
AmuseMe's Avatar
All the power to you Mark I'm not saying that the XT is poorly-made (well, I kinda am), but it could be made better. I mean, there is no need for Swiftech to run their milling machine through the base like they do. It's an absolute mess under there - but as long as temps are good, that is all that matters, eh?
Oh, and about the Swiftech corrosion thing - if you do it right, you wont have corrosion.
  #23 (permalink)
Old March 21, 2010, 06:15 PM
Sushi Warrior's Avatar
I see a lot more people with corrosion on Swiftech blocks than any other by FAR (black corrosion, green corrosion, blue corrosion). I have never seen a corroded EK block (or heatkiller block).
  #24 (permalink)
Old March 21, 2010, 06:47 PM
AmuseMe's Avatar
If you want, Ill PM you pics of some corroded ones lol.
As for the OP: Get whatever you think looks the best for a CPU block out of the ones mentioned.
  #25 (permalink)
Old March 21, 2010, 06:53 PM
MarkOne's Avatar
of course. copper oxyde, it's why Koolance plate them
.... there is no need for Swiftech to run their milling machine through the base like they do. It's an absolute mess under there - but as long as temps are good, that is all that matters, eh?.
funny many complain that Koolance copy the HK, at least Swiftech don't
may be they simply sell more of them
you read to much . those problems was with the gtx , the base was in copper and the top in aluminum plated ... little question here, have you ever play with water cooling , or make plumbing, I can assure you all copper get oxyded
  #26 (permalink)
Old March 21, 2010, 07:46 PM
martin_metal_88's Avatar
After all the debate I will do more search and update it probably tomorrow. Thx guys for all advice!
  #27 (permalink)
Old March 22, 2010, 04:06 PM
So here is an update! After few look at all the water block I could get I finally decide to go with the 360
Koolance CPU-360 (CPU) [no nozzles] Products Model: CPU-360 [CPU-360] : Performance-PCs.com, ... sleeve it and they will come
He is nice looking and review are nice.
WaterBlock : Koolance 360 Rev 1.1
pompe: Swiftech MCP-655, avec EK top et body Bitspower
reservoir: Swiftech Micro-res V.2
radiateur: Thermochill PA120.3
So now what tube and fitting well what's all the other thing do you suggest to me guys!
  #28 (permalink)
Old March 22, 2010, 04:14 PM
AmuseMe's Avatar
You will need two G3/8 barbs or G3/8 to G1/4 adapters regardless:
Bitspower Shining Silver G 3/8 to G 1/4 Adapter Fitting # BP-WTP-C23 - allows the use of any G1/4 barb
EK High Flow Fittings G 3/8 to 1/2in. ID Barb - is 1/2 for 1/2ID tubing
As for tubing and barbs, most people get 1/2ID x 3/4OD tubing. I myself use 3/8x5/8 so I dont need to use clamps on my fittings
Looks at BitsPower Compression fittings
  #29 (permalink)
Old March 22, 2010, 04:19 PM
MarkOne's Avatar
fitting : plain regular barb, compression are way to risky, you pull a hose on a compression and it pull out.. and they cost more , Martin is on a budget,
here the fitting I use on my rigs, 1/2 , since you have already few 1/2 , continue with them
NCIX.com - Buy Bitspower G1/4 High Flow 1/2IN Barb Fittings for 1/2IN ID Tubing (Pair) - BP20065 In Canada.
the tube , if you order your koolance at Ncix , you can grab a Primochild, they are exactly the same as Fezer, chose the color you wants
NCIX.com - Buy Primochill Primoflex Pro LRT Black 1/2IN ID 3/4IN OD Tubing (10 Feet) - PFLEXP10-34-BK In Canada.
here few clamp for your tubing
NCIX.com - Buy Swiftech Adjustable Black Hose Clamps for 1/2IN Inner Diameter 3/4IN Outer Diameter Tubing (2 Pack) - 1/2-CLAMP-X2 In Canada.
  #30 (permalink)
Old March 22, 2010, 04:22 PM
MarkOne's Avatar
wait a minute
the Koolance is G1/4 no need for adaptor , I know I have one...
http://www.hardwarecanucks.com/forum...9-koolance.jpg
Optimal water setup Fudd Rucker Water Cooling 8 October 15, 2009 10:26 AM
Custom Water Cooling Setup BALISTX Water Cooling 37 July 29, 2008 10:02 PM
Need help with first water cooling setup. BALISTX Water Cooling 18 March 23, 2008 10:11 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 07:22 PM
Anyone looking for help with a water cooling setup, please post here Misoprostol Water Cooling 75 September 17, 2007 11:09 AM
