Old October 23, 2007, 08:28 AM
Default My Soon-To-Be loop
Opinions on my soon to be loop?
Swiftech Storm (going to be on an e4300 heading for 3.8 (had it at 3.6 on air just too hot) got it for free :))
Swiftech MCP655 Vario
Performance PC's Cyclone Res
Masterkleer 7/16 - 3/4 toobz
Black Ice GT Stealth 360mm with 3x80cfm Rosewills
Let's take this DS3/e4300 to 3.8. Paying 75 bucks for a CPU like this is gold!
Old October 23, 2007, 09:23 AM
cdn_Madrach's Avatar
What about a Dtek Fusion WB? I believe it's still the best performer and not a bad price.
D-TEK Customs Fuzion CPU Water Block S478/LGA775/S939/AM2/S754 1/2IN Barbs - DirectCanada
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old October 23, 2007, 09:32 AM
Babrbarossa's Avatar
Looks ok- I might choose differently, but those choices are fine on a budget- if you're going for the stealth rad, I might switch the high flow fans for something quieter- I don't think the stealth requires that much force to work well- not a very high resistance rad- not the best cooling rad as a result, but thin and quiet. If you want better cooling and don't mind the noise- get a GTX and some 38mm thick panaflos... I'll also chew up and swallow my own e4300 if you get one to 3.8
Old October 23, 2007, 11:00 AM
Apollo4g's Avatar
I would also get a Fuzion waterblock.
Also how much is that Performance PC's Cyclone Res?
Just get an EK one, i got 2 EK res the other day and they look great, they create cyclones as well, but i dont really like that
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old October 23, 2007, 11:23 AM
The storm is temporary, then I might get a Stinger waterblock, or a Fuzion. They are definitely noticed on my list.
I have a fan controller so I figure i'll be safe with these Rosewills. I was going to go the BIX route and panaflos, but the rad itself is an extra 10 bucks, and almost 30 for fans. Pushing the price higher and higher.
Old October 23, 2007, 12:49 PM
sswilson's Avatar
Looks good.
You can always swap out components if they don't quite meet your expectations (too loud, not cool enough, etc....).
Selling off used WC gear is getting easier as it gets a little bit closer to the mainstream.
Ram Water Cooling loop Shredder Water Cooling 5 January 24, 2008 09:55 PM
Fan loop SpateD Water Cooling 6 January 21, 2008 07:30 PM
Best loop configuration? Cptn Vortex Water Cooling 21 December 8, 2007 12:53 PM
