Old March 19, 2010, 03:17 PM
Default Cleaning a Rad
Ok I'm sure you went "phew not another one" when you saw the title :p..
I'm more interested in finding out the best way to clean dust of the fins area of a rad, a can of air does a fairly good job, but I wanted more gone.
I currently have my triple rad attached in a HAF 932, it's attached from the inside directly to the case and the fans blowing air out, now if I put dust filters on the fans, will that help some how?
Old March 19, 2010, 03:32 PM
gingerbee's Avatar
yes dust filters will help i have a same case with the rad in the same place and the only way i clean my rad is with air cans and i pull the my loop apart. just blow through.
Old March 20, 2010, 09:29 AM
Dazmode's Avatar
Just blow it with compressed air.
Orange Build: Final Video
HTPC Build: Final Video
[FS] Spring Cleaning JD Buy/Sell & Trade 6 June 2, 2009 09:37 AM
[FS] Cleaning Up my Closet lcdguy Buy/Sell & Trade 6 April 7, 2009 07:44 AM
cleaning your LCD mo' power Display Units 20 January 17, 2009 07:32 AM
Driver Cleaning Scart O/S's, Drivers & General Software 5 December 23, 2008 11:21 PM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
